Brake light stays on?
Today I was driving and parked my car at Wal-mart. Came out and noticed my brake lights are on. I'm like wtf? Press the brake no change. Check the instrument/tail light fuse and it was good and still changed it anyways. Brake lights did not turn off when I took the fuse out. Tell me what's wrong?
Is it the switch under the brake pedal?
Re: Brake light stays on? (duggy)
I bet you the rubber stopper on the brake pedal lever came apart...now there's nothing to depress the switch turning your lights off. I've seen it happen on several civics.
Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy »</TD></TR><TR><TD CLASS="quote">So you're tellin me when the car gets low on brake fluid the lights turn on?</TD></TR></TABLE>
They are confused by your title since it says "brake light stays on".
Have you done any wiring lately?
Ah, I guess I didn't make it clear.
Only wiring I've done lately is change out the main relay.
I'd like to know more about this rubber stop on the pedal.
Took out the switch. Put it up to an ohmeter and it had continutiy when i connected and didnt when i pressed the button. Seems to be working fine?
Imperious: Mod of Valor
Re: Brake light stays on? (Coyote1800cc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coyote1800cc »</TD></TR><TR><TD CLASS="quote">I bet you the rubber stopper on the brake pedal lever came apart...now there's nothing to depress the switch turning your lights off. I've seen it happen on several civics.</TD></TR></TABLE>
This is usually what happens.
musclehead954
02-27-2008 10:28 AM
Nocturnal
09-24-2005 12:23 PM
