brake fluid
Old 02-18-2005, 01:51 PM
undercoversi's Avatar
Default brake fluid
just wondering what kind of brake fluid you guys are running? i have a 2000 si and i need to pick some up. whats the best?
WyteNyteGSR's Avatar
Default Re: brake fluid (undercoversi)
dot 3
Old 02-18-2005, 01:55 PM
Default Re: brake fluid (WyteNyteGSR)
well yea i know that i was just wondering if theres any differences from brand to brand or what not
_BEN_'s Avatar
I use the valvoline stuff at autozone. Its in the greyish silver bottle.
Its always there and priced competitively.
If you want something a little better like ATE superblue you will probably have to mailorder it or special order it from you shop.
Old 02-18-2005, 02:01 PM
I am a (Trial User) Army
litterbox's Avatar
Default Re: brake fluid (_BEN_)
Go to Honda and get their brake fluid.
Old 02-18-2005, 02:33 PM
Team Purple
Honda-Tech Balla's Avatar
Default Re: brake fluid (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Go to Honda and get their brake fluid.</TD></TR></TABLE>
Old 02-18-2005, 02:34 PM
Tiferet's Avatar
DOT 5
Old 02-18-2005, 02:35 PM
KayOs's Avatar
ATE Blue or Honda brake fluid
Old 02-18-2005, 02:36 PM
SOHCD16y8's Avatar
PRESTONE DOT 3
Old 02-18-2005, 03:24 PM
B18C2_sedan's Avatar
Ok I a hydraulic mech and you are just wasting your money buying top of the line fluid. Dot 3 or 4 is fine for normal driving. The biggest cause of fluid going bad is old age. Your service manual has the proper time change requirements. Liquids are incompressible and that is the bottom line. Water would even work in a emergency. Save your money.
Old 02-18-2005, 03:27 PM
SOHCD16y8's Avatar
Default Re: brake fluid (B18C2_sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C2_sedan &raquo;</TD></TR><TR><TD CLASS="quote">Ok I a hydraulic mech and you are just wasting your money buying top of the line fluid. Dot 3 or 4 is fine for normal driving. The biggest cause of fluid going bad is old age. Your service manual has the proper time change requirements. Liquids are incompressible and that is the bottom line. Water would even work in a emergency. Save your money. </TD></TR></TABLE>
indeed
Old 02-18-2005, 04:00 PM
_BEN_'s Avatar
Default Re: (L.D.S. Construction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L.D.S. Construction &raquo;</TD></TR><TR><TD CLASS="quote">DOT 5</TD></TR></TABLE>
Your nuts.
DOT 3, 4 and 5.1 systems are incompatible with DOT 5 fluid.
Old 02-18-2005, 04:40 PM
ejprimo's Avatar
Default Re: (_BEN_)
castrol Lma Gt dot 3/4 from pep boys at $5/qt. Lma stands for low moisture absorbing.
Old 02-18-2005, 05:54 PM
Mr. Samurai's Avatar
Default Re: (ejprimo)
Just got new rotors and pads from stoptech, I also got Motul RBF 600 DOT4 brake fluid, not sure if its over doing it or not. we'll see how it goes
Guimba
Suspension & Brakes
02-17-2010 06:05 PM
blipmode188
03-07-2009 01:56 PM
blkgsr03
04-16-2004 09:21 AM
jdm92accord
01-30-2002 09:29 AM
Quick Reply: brake fluid
