Brake Booster Vaccum leak problem!! Need some help - Honda-Tech
Old 05-27-2010, 09:58 AM   #1
Markb16a's Avatar
Default Brake Booster Vaccum leak problem!! Need some help
I have a problem with my brakes the pedal goes all the way down to the floor when I push on it and sometimes it will hold a lil bit. I got a new maaster cylinder and used the old brake booster. This is what i did though. I know some of you guys are flipping your brake booster around to hide the vaccum line to the intake manifold, well that is what I did. My brake booster is leaking from where there is a notch in the booster I bought another one and haven't put it on yet but that one has a notch on it as well. has anyone ever had this problem if you are one of those guys that flipped your brake booster around to hide your vaccum line? Should I just flip it back over to see if it stops leaking? Or should I install the new one? very small leak btw. I also tryied gasket sealer metal bond the vaccum goes right threw it.
Markb16a is offline   Reply With Quote
Old 05-27-2010, 10:18 AM   #2
Default Re: Brake Booster Vaccum leak problem!! Need some help
Quote:
^^^This is not a brake booster problem. You probably just need to properly bleed the hydraulic system, assuming there are no fluid leaks.
The vacuum leak from the brake booster is a separate problem. Just install the new booster you have.
Former User is offline   Reply With Quote
Old 05-27-2010, 10:19 AM   #3
philosofy1's Avatar
put it back to the way it was, brakes are to important! if the problem persists, then change the booster.
philosofy1 is offline   Reply With Quote
Old 05-27-2010, 10:25 AM   #4
Markb16a's Avatar
Quote:
I think I might do that. change it back to normal. I did test it for vaccum leaks and basically the brake booster is good but it is hissing from the notch on the brake booster.
Old 05-27-2010, 08:20 PM   #5
Markb16a's Avatar
ok i flipped the brake booster back over and when I press on the brake pedal, it would gradually go down still. I mean when I come to a stop or something the pedal will not hold it will go down to the floor when pressed. I still got a leak somewhere could that be the master cylinder or the brake booster?
Old 05-27-2010, 08:30 PM   #6
I guess you don't read posts in your thread:
Old 05-27-2010, 08:44 PM   #7
Markb16a's Avatar
what about if I were to bench bleed the master cylinder? because I read on a tech article if the brake pedal is pressed and the pedal goes down that means the master cylinder is bad. Also my vaccum leak in my brake booster is gone as well. No more leak so it has to be a master cylinder issue. I must still have air in my lines after bleeding.
Old 05-27-2010, 09:36 PM   #8
BatuKing's Avatar
To check if your booster is leaking do this. Turn on your car, and press on the brake pad. Now turn it off, if the pedal starts to rise and get stiffer on you then the booster has a leak. IF the pedal stays the same, your booster is fine.
Now what your describing sounds like you had a bad master cyl and you did not bleed the fluids correctly. Continue to bleed all 4 sides untill the fluid is clean then press the pedal to test.
BatuKing is offline   Reply With Quote
I push on the brakes and idle goes up ? DUKE LADUKE Honda Civic / Del Sol (1992 - 2000) 25 05-10-2011 10:21 AM
Front brakes keep on locking up on my 95 DX!??!?!?!?!?!? Jowee Honda Civic / Del Sol (1992 - 2000) 0 01-14-2007 02:37 PM
brake booster (WOOT) & will not hold vaccume oldSCHOOLhonda Honda CRX / EF Civic (1988 - 1991) 1 04-24-2005 10:10 AM
Brake Booster vacuum line TypeDC4 Forced Induction 2 10-23-2003 06:13 AM
FAQ: Integra MC and Brake Booster facts all of you guys should know about... FourthGenHatch Honda CRX / EF Civic (1988 - 1991) 33 10-06-2003 10:36 AM
Tags
2004, accord, air, booster, brake, civic, crx, flip, hiss, honda, install, leak, leaking, master, odyssey, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
