Brake Booster Problem? NEED HELP!!
Old 06-02-2009, 09:48 PM
PhatFactory's Avatar
Default Brake Booster Problem? NEED HELP!!
Okay, I just recently swapped the whole GSR disc conversion (front&rears), new pads, new brake hose, new master (15/16), and a used 40/40 proportioning valve and GSR booster (290V). I'm having a wired problem, when I'm driving the car it brakes fine, but after awhile the brakes lockup? after it cools down its fine. My question is, is this a possible cause of a bad booster? Like I think the booster rod is getting stuck or something. Also it has a vacuum leak (where the master bolt's to the booster) is this a problem?. Has anyone have this problem? Also can't I just swap over the DX stock booster and used the 15/16 master? Please help me, Thanks.
Old 06-02-2009, 10:56 PM
Ruben19's Avatar
Default Re: Brake Booster Problem? NEED HELP!!
remember all gsr came with abs.
possibly a plugged brake line
Old 06-03-2009, 07:39 AM
So what are you tryna say? bump
Old 06-03-2009, 08:15 AM
I'm not Rick!
rick_rabies's Avatar
The vacuum hose that goes from the intake to the brake booster is backwards...yes it matters what way the valve thingy in the middle is facing.. go to www.kenskustomchassis.com and order a boosterless mastercylinder..i did. its real nice...and clean
Old 06-03-2009, 01:42 PM
Well I doubt it's backwards cuz I didn't even touch it when I installed the booster beside the one going to the booster. I checked out the link, that boosterless master looks nice how much do they run for? I just picked another booster from the junkyard for 50 bucks so if that don't work I'll try the boosterless one. Again thanks fam.
Specail Ed
06-23-2019 12:03 PM
Markb16a
05-27-2010 08:36 PM
JRSC EM1
12
11-08-2003 10:41 PM
Quick Reply: Brake Booster Problem? NEED HELP!!
