Brake Bleed procedure ? - Honda-Tech
Old 03-15-2012, 04:52 PM   #1
shesinmyroom's Avatar
Default Brake Bleed procedure ?
I have a 93 civic si, I forgot what the brake bleed procedure was if someone could tell me it be great
shesinmyroom is offline   Reply With Quote
Old 03-15-2012, 04:54 PM   #2
Default Re: Brake Bleed procedure ?
See FAQs sticky.
Former User is offline   Reply With Quote
Old 03-15-2012, 05:18 PM   #3
Master Detailer
98civdx's Avatar
Right rear, left rear, right front, left front.
98civdx is offline   Reply With Quote
Old 03-15-2012, 05:29 PM   #4
Thanx !
Old 03-15-2012, 09:49 PM   #5
Kohen's Avatar
Quote:
Everyone seems to think this is the right way, but I was reading threads and people say the Helms manual says "passenger rear, driver front, driver rear, passenger front." Something about the first two being connected and the last two being connected. But.. It really doesn't matter. haha
Kohen is offline   Reply With Quote
Old 03-15-2012, 10:06 PM   #6
Master Detailer
98civdx's Avatar
I was told by a Honda master tech to do it like that. lol
Old 03-16-2012, 07:20 AM   #7
cvcrcr99's Avatar
I believe 98civdx is correct. You work from the farthest away from the master cylinder, to the closest.
cvcrcr99 is offline   Reply With Quote
Old 03-16-2012, 07:58 AM   #8
Kohen's Avatar
Yeah that's what I read the most. But in my reading two people posted basically, "My helms manual says "passenger rear, driver front, driver rear, passenger front"." Then another said "Weird, mine does too." Just thought I'd bring it up. But like I said, it won't really matter.
bleeding clutch mattbatson Honda Civic (2006 - 2015) 2 04-14-2013 05:54 AM
Mushy brake pedal/pedal drops to floor even after a brake fluid bleeding flush dgdarien Honda Civic / Del Sol (1992 - 2000) 5 09-25-2009 07:25 PM
brake line bleeding 96 accord antilock brakes flyinga Honda Accord (1990 - 2002) 3 03-19-2009 11:09 PM
Proper Clutch Bleeding. TravisCadello Honda Civic / Del Sol (1992 - 2000) 2 10-29-2008 08:12 AM
How to bleed the radiator fluid wantmorepower Acura Integra Type-R 3 02-21-2004 01:14 AM
Tags
1991, 2000, 93, bleed, bleeding, brake, brakes, civic, front, honda, hondatech, left, looked, people, procedure, rear, tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
