bouncing rpms?
Old 06-14-2009, 08:53 PM
EJ1civic coupe's Avatar
Default bouncing rpms?
just started today..after driving alittle i stop at a light n my car starting bouncing rpms..usually idles at 500..today it was idling at 1000 and kept bouncing to 1500 while idling at the light..only seems to do it when the car is fully warmed up..its d16z6..im thinking its a vacum leak..any other options?
Old 06-14-2009, 08:56 PM
ej1love's Avatar
Default Re: bouncing rpms?
dirty iacv...
Old 06-14-2009, 09:03 PM
slow96lude's Avatar
x2 on the IACV
Old 06-14-2009, 09:06 PM
thnx man
Old 06-14-2009, 09:08 PM
slow96lude's Avatar
take the IACV off and clean the screen and also make sure you put 12 volts to and make sure that the valve in there moves smoothly.
Old 06-16-2009, 07:54 PM
took iacv off..cleaned and ran 12 to it..valve ran smooth..help alittle by cleaning it..had a steady idle at 1000..still bounces alittle 1000 to maybe 1200..a slow bounce..doestn constly do it tho..what else could be a little prob..didnt check ny vacum lines yet
Old 06-16-2009, 08:07 PM
slow96lude's Avatar
what year car are you driving because your FItV could need a good cleaning too
Old 06-16-2009, 08:13 PM
95 civic ex
Old 06-16-2009, 09:44 PM
eg grom's Avatar
Not sure about the FItV, but a loose vacum line could possibly be the culprit
Don't quote me:
But I had once heard that if your car begins to give trouble starting with weather fluctuation it could be a good indication on the IAC
Old 06-16-2009, 09:51 PM
Former User's Avatar
As mentioned by slow96lude, clean the FITV as described here.
Old 06-16-2009, 11:46 PM
tkda's Avatar
if that doesnt do it, check the coil in the distributor.
Old 06-17-2009, 03:00 PM
sounds good..ill try cleaning the fitv to see if thats the prob..after i cleaned the iacv it idled at 1000 fine then a day after it started doin it again just not as rapidly
charliecd5
12-28-2014 01:59 AM
civiccoupe95
03-09-2009 06:47 AM
drock305
11-07-2007 06:56 PM
the.hamburglar
05-10-2007 08:46 PM
snezze21
09-08-2006 11:21 PM
Quick Reply: bouncing rpms?
