Bolt on Catalytic converter for EG w/ B18B1 swap - Honda-Tech
Old 03-05-2011, 01:50 PM   #1
hefftone79's Avatar
Default Bolt on Catalytic converter for EG w/ B18B1 swap
I need a catalytic converter for my 93 Civic CX with B18b1 swap. I'm using the stock B18b header, I have an aftermarket exhaust, but no cat (nor test pipe)
I know that the flanges are rotated between some integras and civics...Is there a stock bolt-in CAT that will fit (aligned bolt holes and proper length). Will a stock integra CAT fit? I need to get emissions done, and plan to keep the car NA during break-in then finishing up the turbo, with a down pipe and 2.5" Cat. But until then, a stock cat will get me by.
hefftone79 is offline   Reply With Quote
Old 03-05-2011, 01:56 PM   #2
tlarimer's Avatar
Default Re: Bolt on Catalytic converter for EG w/ B18B1 swap
I used a OEM B16A header on my B18B1 in my EH3, it was tight but fit and allowed me to use the OEM EH3 cat and exhaust system.
Edit: When I say tight, I mean to the front of the block and oil pan. I had to give a few love taps with a ball peen hammer to one of the lower pipes to get it to clear the block. But it was a temporary engine for me, just needed to get it running.
tlarimer is offline   Reply With Quote
Old 03-06-2011, 05:42 AM   #3
hefftone79's Avatar
Thanks for the reply, I don't intend on buying a different exhaust manifold/header. I'd think something will work with the setup I have, whether its Integra, Del sol Vtec, or EK Si.... Anybody know?
Old 03-06-2011, 09:00 AM   #4
blown_ss's Avatar
a integra cat will work. i have it on my eg with a b18b1 in it.
blown_ss is offline   Reply With Quote
Old 03-06-2011, 03:38 PM   #5
hefftone79's Avatar
Awesome, thanks for the reply. I actually live in Dallas, Ga now. As far as the internet goes that practically makes us neighbors.
Old 03-06-2011, 06:57 PM   #6
I believe it's the JDM ITR manifold that the flange is rotated funny. You can always cut the pipe and go to an exhaust shop to get it rewelded.
NotAJDMFanBoy is offline   Reply With Quote
Old 03-06-2011, 07:11 PM   #7
Seagull Management
94EG8's Avatar
stock LS manifold/downpipe + DX cat and catback all bolts up IIRC.
94EG8 is offline   Reply With Quote
Old 03-21-2011, 07:03 PM   #8
hefftone79's Avatar
I ordered an integra LS "test-pipe" from ebay and the flanges are not lining up....
So frustrated!
Old 03-22-2011, 03:37 AM   #9
rhymeshark916's Avatar
Whatever cat. converter you get, if it's doesn't fit then you know what to do. That's the simplest answer to your question. When doing engine swaps, not everything is going to fit between different chassis. Usually, you're b-pipe needs to be shorten.
rhymeshark916 is offline   Reply With Quote
Old 04-30-2011, 01:18 PM   #10
hefftone79's Avatar
Trying to figure out what actually fits,.....since I don't have anything to work with at the moment, I will have to buy one......I rather be closer than farther away from gettting this on the road.
Old 05-13-2011, 03:58 PM   #11
hefftone79's Avatar
I ordered a bosal converter for a 94 integra Ls.... it is the correct length, but the three bolt flange is slightly cocked. Converter body seems a little bigger, and may contact the suspension subframe.
I stopped at autozone, picked up a converter for a del sol (basically the same as a civic)...the one I got is Maremont 29132...it is sold as direct-fit, but the three bolt flange is made to slide in to the catalytic converter, then be clamped. This makes clocking the flanges a breeze, but the converter is a tad short (16.5" long) for the clamp, but MIGHT work if welded.....at least this saves having to cut (straight) and reweld..... the pipe diameter does seem a little small, the rear end of the converter is 1-7/8" (ID) pipe, but the pipe that slides into that (with the 3-bolt flange) is 1-5/8" (ID).... That's not exactly ideal stepping up from 1.625 to 2.50....
Another option is Maremont 29183 (for 1995 integra LS), which my autozone rep said is "unavailable through them" (so use google)...... this one is 17.6 inches long so it should be easy to clock and clamp. It uses the same two piece design.
Old 05-13-2011, 04:13 PM   #12
hefftone79's Avatar
a better picture....
JDM B18C in EK exhaust / catalytic converter fitment -Justin- Honda Civic / Del Sol (1992 - 2000) 6 11-09-2015 07:50 AM
JDM B18C in EK exhaust / catalytic converter fitment -Justin- Hybrid / Engine Swaps 1 11-09-2015 04:14 AM
How to fit 70mm cat-back to swapped EK? Hatch It Honda Civic / Del Sol (1992 - 2000) 0 04-19-2014 07:24 PM
What Honda catalytic converters fit civic? Azimmer Honda Civic / Del Sol (1992 - 2000) 1 05-21-2012 01:20 AM
catalytic converter problem on a ek hatch w/ gsr swap! lilvpboijr2 Honda Civic / Del Sol (1992 - 2000) 1 12-01-2011 02:28 AM
Tags
18, b18b1, cat, catalytic, chevy, civic, converter, exhaust, fits, hatch, honda, kind, pipe, s10, s2000, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
