blinker problem (already did a search)
Not the typical "hyper blinking" issue that alot of people have.
The car is a 93 Civic EX. While my headlights are off, the blinkers work fine...... no problem whatsoever
But once i turn my headlights on, my left blinker indicator stays lit and the left blinkers wont work at all.
Re: blinker problem (speedaholic)
sounds like you have a short somewhere. or maybe a ground is loose. check the wires and grounds that go from the headlights/corners to the steering column
Re: blinker problem (speedfreek128)
you have the same problem my friend had with his Grand Am, he put in a new fuse and put in new headlight bulbs and it went straight
Re: blinker problem (mike0980)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike0980 »</TD></TR><TR><TD CLASS="quote">sounds like you need more blinker fluid.</TD></TR></TABLE>
I'm always running out of the stuff
