bleeding the brake
Re: bleeding the brake (xaznxdrgnxboix)
simple. just start with the rear passenger, find the bleed plug loosen it, put maybe a clear tube or something onto the bleed hole so you can see if the air bubbles are gone. okay have someone pump the brake lets say 3 times then hold. tighten the screw let em pump 3 times and hold and loosen it and it should squirt out. make sure theres no air bubbles, has to squirt pure fluid through the tube and make sure the brake resevoir is filled with your brake fluid at all times. repeat through all brakes starting with rear passenger ,front driver, rear driver, and front passenger.
you may pump the system as many times you like if you dont feel that all teh air bubbles are gone.
RTW DC2R
05-18-2005 09:23 AM
