the big 3 question
the big 3 question
92 civic si
hey i need to do the big 3 for my 92 civic
i have a few questions on locations
1 battery ground to chassis ground
is the oem location the best ground for this one?
2 tranny ground and chasis ground
are the oem grounds the best locations as well?
3 alternator power
this one is a little confusing
do i remove the oem wires and wire a new power to the oem fuse box and then from the fuse box to the battery?
or do i not use the oem fuse box and make my own fuse?
is there a ground for the alternator?
3 alternator power
Re: the big 3 question
3 alternator power
3 alternator power
1. OEM is the best location, but grounding on the heavy metal is best (ie - don't ground to thin metal). Try to keep grounds going to the same location as electricity will take the path of least resistance.
2. Yes. Honda knew what they were doing. You can change it but see answer #1.
3. Alternator grounds itself through the mounting to the engine (like the starter). I ran my own inline fuse for the ALT as the power wire went to my power distribution block I now have in the engine to run power to the starter, fuse box and alternator. You can also continue to use the fuse box power supply which has a fuse built into it.
If you are not sure seek help from a professional shop. This is not something to "play around with" as it can burn down your car!
Location of the actual ground doesn't matter as long as it's solid metal. ( all paint/coatings scrapped off) Using the OEM location is often the easiest.
Do not remove the original wire, just piggy back it. You don't need to fuse it.
here are some pictures of all the grounds i only found 3
this is the only battery to chasis ground
seems easy enough to put a bigger guage wire here
this is a good mounting location? its all oem
this is the only engine to chasis ground i could find
looks like its going to the bracket for the power steeering pump
shouldnt be too hard to change this one
now those shouldnt be too hard to do but the alternator power wire is confusing
heres some pictures
now theres a black wire from the positive battery going to the fuse box im not sure what this is? do i need to upgrade this wire?
the white wire is the alternator power wire thats going to the fuse box as well
now i dont think i can fit a terminal in there as u can see in the picture
heres some pictures
You know I'll just come right out and say it- WTH are you trying to do, fry parts of your car's electrical system or just set your car on fire?
As everyone else has said you have supplied no details other than the year & make of your car and Honda chose those ground locations for a reason.
This post was not a request and is required information.
You've had quite the conversation and have dodged this most basic rule of this and most tech forums.
Your thread is now locked because of dodging this simple yet critical and helpful information.
If you wish to change that situation and add your required vehicle information (year, make, model, trim, and modifications), please shoot me a PM and I will unlock it so you can do so.
Looks like I had a senior moment. Thread opened.
EDIT: Okay so a google search for "the big 3" turned up results of "upgrading" power wires for higher output to a sound system....geez the OP REALLY SHOULD HAVE SAID THIS BEFOREHAND!
How To Perform The Big 3 Upgrade | Learning Center | Sonic Electronix
My personal advice-get an electrical diagram with ground locations for your car ([cough] read the FAQ [cough]) and take the damn battery OUT of the car if you are messing with the wiring. The questions you are asking indicate you don't have one and the pictures WITH THE BATTERY STILL IN THE CAR while you are apparently messing with wiring lead me to be very concerned for your safety. Electrical current is NOT something to screw with period end of story. In addition to frying expensive parts of your car (starter, alt, dizzy, ecu/pcu, etc) doing what you are attempting to do with power still hooked up and current flowing can result in serious injury or death to you the end user.
Le13lanc
08-29-2016 06:43 AM
rick_rabies
05-02-2009 11:24 AM
wicked_b16eg
01-06-2008 11:13 AM
