Best way to remove pin strips
Re: Best way to remove pin strips (jgop_151)
I picked away at mine with my fingernail and used Goo Gone to take the residue off
The sticky stuff will also come up with some rubbing compound, but it's kind of a PITA, so Goo Gone sounds like a better idea.
Re: Best way to remove pin strips (uncivilCivicinprogress)
Also if you heat them up a bit with a blow-drier they come up pretty easy.
Then wax the chit out of the car.
Re: Best way to remove pin strips (97hb)
On my Civic, it had two colors. Silver and black. The black was very easy to get off, you just peel with your fingernail. The silver was a pain in the ***. As your pulling it off, just ahead of where your peeling, apply hot air(blowdryer) and it'll look better in no time.
Seeing that I had pinstripes on my car since 93, the fingernail trick didn't work. I think I'll try the hairdryer bit. Anyone ever do the hairdryer thing on an old hatch like mine?
Re: Best way to remove pin strips (hatchback)
Where do you get Goo Gone, btw>?
and does it **** work on plastic?
Re: Best way to remove pin strips (RICErocket03)
also blow dryers or heat guns help a lot to loosen the glue on the pinstripes and then just go over the area afterward with goo gone or some other sticker label remover to remove the remaining "****" left over that doesnt come off with the pinstripes
I found mine came off easier when it was cold rather than heated up with a blow dryer IMO.
[Modified by WhiteEJ1, 12:45 AM 12/11/2002]
Re: Best way to remove pin strips (WhiteEJ1)
heat up the pin stripes with a heat gun or hair dryer...it breaks down the adhesive and is easier to get off
for older cars it is easier to use a razor blade to get them (be careful)..new cars could prolly use fingernails....
if you use goo gone...or goof off..or aceytone or anything like that make sure once you get the adhesive off your car..u was the goo gone off too
I dont recomend using it on plastic, leather or anything like that..it tends to eat away at the color..and if you leave it on your paint it will eat through the clear coat and paint
oh yea i almost forgot...wax your car afterwords or buff it if you have one...it helps to build up the clear coat which was slightly damages/removied during the process
Have Fun
Have Fun
