Bent valves?
Old 03-18-2012, 04:49 PM
wtfisvtec??'s Avatar
Default Bent valves?
I was driving today and was only pulling the car to 6 1/2 grand when everything shut down on it. all 4 plugs have spark, dont have a compression checker but i removed the valve cover and held my hands over the spark plugs and it felt good on all 4. There is white smoke coming from the head which smells like exhaust. Could this be bent valves or could they be stuck?
Old 03-18-2012, 04:55 PM
nealnanoHX's Avatar
Default Re: Bent valves?
Sounds like you may have lost the timing belt. Pull the upper timing cover and check the belt out. Valves dont just bend but will if you loose the timing belt. Like the one thing I dont like about Hondas. I broke the timing belt on my Supra turbo while racing under full boost well over 5k rpms and not bent valves or any damage, motor just shut down. Do that to a Honda and the valves are toast.
Old 03-18-2012, 04:57 PM
the belt is 100% ok
Old 03-18-2012, 05:12 PM
hannslebo's Avatar
OLD SCHOOL TRICK TO CHECK FOR BENT VALVES:
-Get a uncreased piece of white lined paper (Not construction paper or similar its too thick)
-Let your car warm up to operating temp and allow it to idle
-Hold the paper flat over your exhaust so it covers the end completely
-Watch the paper closely, if all is normal it should just keep flapping outward. If you have a bent valve the paper will get sucked into the exhaust before it is pushed out
Old 03-18-2012, 05:15 PM
LSVTAK_EK's Avatar
Do you have a rev limiter at 6-1/2k? I've not got my ecu chipped with a baseman yet and it cuts out at 6-1/2k!
Old 03-18-2012, 05:16 PM
LSVTAK_EK's Avatar
That is a cool trick!! Good to know!
Old 03-18-2012, 06:24 PM
No revlimiter is set at 8200, pull all my plugs out and the one on cylinder 4 has oil on the bottom of it
Old 03-18-2012, 07:02 PM
dlstech's Avatar
This could be blowby. Plus you said you have oil in one cylinder. Rings are probably toast.
Old 03-18-2012, 07:31 PM
Gonna pull everything apart tomorrow and take a good look at things. since ive turbod it im pry just gonna build the block and buy all new oem parts for the head and do things the right way. whats some good sites to order pistons/rods??
Old 03-18-2012, 07:36 PM
its a b16a turbo, any suggestions on a good combo to use?
Old 03-18-2012, 10:06 PM
Shaunathan's Avatar
there are some good deals on here for pistons and rods, the best i'd personally say are wiseco or cp pistons & Eagle or BC Rods (brian crower)
Old 03-18-2012, 10:19 PM
DCRB's Avatar
perhaps you spiked and bent a rod?
lsvtec2000
01-03-2008 07:05 AM
JSpekBB4
09-05-2006 08:02 PM
HaTcH_BmX
06-01-2003 03:57 PM
AK94GSR
05-10-2002 09:39 AM
Redline130
08-13-2001 10:09 PM
Quick Reply: Bent valves?
