Battery won't stay charged , alternator is good also. 00' civic si - Honda-Tech
Old 09-14-2011, 06:04 AM   #1
Default Battery won't stay charged , alternator is good also. 00' civic si
Ima try and make it as clear as I can the car is a 2000 Honda civic Si , basically stock, I got the battery checked and it was bad so I put a new one in and it turned right now it drove good and started good for about two hours, before that I had took the alternator off just to make sure it wasn't bad and I went to autozone got it checked and it was good, so I put it back on yes the belt is tight, and I then replaced the battery and it worked fine for the rest of the night, now it won't stay on without me revving up the motor, if it's at idle it will be fine but as soon as I press the brake pedal it'll turn off same goes if I try turning on corner lights or anything. So what I need to know is what can I check next? Grounds? Fuses? Any in specific? Any help will be appreciated.It also threw about 7 codes which are the following; p1298- Electric Load Dectector (ELD)Circut High Input. P0135-heater condition (heated oxygen sensor bank sensor 1&2) P0500-VSS circuit malfunction . P0300-random cylinder misfire. P0304-cylinder number 4 misfire detected.
Jdmbryan is offline   Reply With Quote
Old 09-14-2011, 06:06 AM   #2
Default Re: Battery won't stay charged , alternator is good also. 00' civic si
Is 7.5A dash fuse 15 blown?
Former User is offline   Reply With Quote
Old 09-14-2011, 06:11 AM   #3
Bro that happen to my prelude i went thru like 3 batteries, my problem was a wire shortage so check all of ur wires
Gi'Joe Rosario is offline   Reply With Quote
Old 09-14-2011, 08:11 AM   #4
My inital thought was the fuse also as Ron stated. If it's blown, it will not charge as the circuit is open.
Anderson413 is offline   Reply With Quote
Old 09-14-2011, 09:31 AM   #5
ChristianL's Avatar
Do you have a volt meter (or can you borrow one)? If so, get the reading off the alternator while the engine's running. I know it just got checked, but it'll give us more info to go with.
Since it seems to get better when you rev the motor, I'd say it's not the battery. However, I'd agree with Gi'Joe that it's probably a wiring issue. Try checking connections at the alternator, and clean the grounds.
Also, check cables going to the battery leads. I've had loose ones before that seemed to go on tight, only to find I could slip them off with a little wiggling.
Are you running any extra stereo equipment or other electrical goodies?
ChristianL is offline   Reply With Quote
Old 09-14-2011, 09:52 AM   #6
thatboyrob's Avatar
Happened to me a couple weeks ago, replaced the battery, took the alternator out and got it tested, but it still kept draining my battery. Ended up being my battery cable from the positive terminal was worn and no good.
thatboyrob is offline   Reply With Quote
Old 09-14-2011, 08:11 PM   #7
So it was Somethen to do with my wiring somewhere in between the alternator and battery it had a short, got that fixed , now I need new terminals, haven't looked around or googled but anyone want to tell me how to change them?
95 accord Start misfire, won't start at all impossible rock fix Adnneby Reynoso Honda Accord (1990 - 2002) 4 08-11-2016 11:20 AM
crank no start after head gasket replacement 82z280x All Motor / Naturally Aspirated 11 04-10-2015 12:12 PM
2000 CRV Misfire Problems (Compression is ok) BlueWhale Honda Element & CR-V 6 01-16-2014 12:51 PM
battery light not coming on vegas hoe Transmission & Drivetrain 6 06-03-2009 03:12 PM
HELP!!! 88 accord starting problems shanna Honda Accord (1990 - 2002) 9 02-03-2004 05:06 PM
Tags
alternator, baterry, batery, battery, cbarged, charge, charged, chargef, civic, fill, fuse, good, stay, water, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
