What engine oil are you using?
Old 07-14-2008, 06:27 AM
JDM EJ2's Avatar
Default What engine oil are you using?
There is the question, what oil are you using for what kind of set up? Just trying to get a general idea. Thanks guys
Old 07-14-2008, 06:29 AM
JDM EJ2's Avatar
Default Re: What engine oil are you using? (JDM EJ2)
I'll start off. I use Mobil1 10W-30 with a B&G MOA Friction Modifier in my JDM B16 I/H/E.
Old 07-14-2008, 06:58 AM
trickytron's Avatar
94 Hatch D15B (SOHC Vtec):
I use Royal Purple 10W30. I don't tend to use conditioners, but I have used Restore before. I got it @ Advance Auto Parts. It worked well for my Accord with 170XXX + (F22 motor), never burned any oil. I have always used K + N oil filters.
I highly recommend the Royal Purlple Synchromax manual transmission fluid, especially for hard driving applications. They also make ATF, and coolant additives, which I also use and recommend.
Old 07-14-2008, 08:23 AM
devney's Avatar
99 B18C1, intake, exhaust
Castrol GTX Synthetic Blend 5w30
Old 07-14-2008, 09:04 AM
318 Curves, 11 miles
Vindicator9000's Avatar
Default Re: (devney)
2001 B18C1. Using conventional Pennzoil 5W30. Was using Castrol conventional 5w30 on my old d16y8 with 200K miles - never a leak.
Old 07-14-2008, 09:16 AM
djviet2000's Avatar
Default Re: (Vindicator9000)
98 B18C1 I/H/E/Cams/Manifold Mobil 1 Synthetic 10w30 wit honda oem oil filter
Old 07-14-2008, 09:20 AM
Techy's Avatar
Mobil1 Full Synthetic 5W30 with Wix filter on a USDM B16A2.
Old 07-14-2008, 10:13 AM
teaL_EG 2.2's Avatar
Default Re: (Techy)
Regular castrol GTX
Old 07-14-2008, 05:37 PM
darksolguy's Avatar
royal purple full synthetic 3qts 20-50 and 1qt 10-30 ... stock type r block and fully built gsr head...
Old 07-14-2008, 07:21 PM
OMGWTFBBQ!'s Avatar
JDM B18C R, 98+ Spec, I/E, Mobil 1 10w30. Fram oil filter, because they have the hand grip thing on the end and I dont have a filter wrench
I only use Mobil 1 because Autozone never carries Royal Purple in 5w30 or 10w30, and I like to use my $20 discount for oil changes.
Old 07-14-2008, 07:27 PM
Syndacate's Avatar
Both on my D16Z6 (I/H/E) and my D16Y8 (I/H) I run/ran Mobil 1 fully synthetic 10w30 (green!) with an autozone filter.
Never had a problem.
EDIT:
I don't use additives to make it last longer, or seafoam, or any of that jazz - I also don't use the "5000 mile no change" line of Moibl 1 or whatever - I use the regular and change it every 3000.
Old 07-15-2008, 12:53 AM
sugarfree's Avatar
castrol edge 5w30
(used to be called castrol formula r)
dont kno if american got that or not....
Old 07-15-2008, 02:24 AM
tortis's Avatar
castrol gtx in all three of my stock honda's
Old 07-15-2008, 02:29 AM
riceburnerryan's Avatar
ive been getting my oil changed at honda because im lazy haha
Old 07-15-2008, 03:31 AM
coupej1's Avatar
Sohc zc vtec-built head-i/h/e--royal purple 10w30 with fram filter
Old 07-15-2008, 07:11 AM
jdmboss's Avatar
Default Re: (coupej1)
greddy gr1
Old 07-15-2008, 07:14 AM
na+b18c_hatch's Avatar
95 gsr, 98 itr, 96 jdm itr and 98 gsr ==== mobil 1 5w30 full synthetic (always)
Old 07-15-2008, 09:30 AM
EhDriver's Avatar
Default Re: (na+b18c_hatch)
20w50 for all my motors,
Old 07-15-2008, 10:00 AM
D16SohcVtec's Avatar
I'll be running Rotella T Full Synthetic 5w40 in my Del Sol. Built D16z6 + Boost.
Old 07-15-2008, 11:20 AM
groundzerocivic's Avatar
Mildly built LS/VTEC= mobil 1 full syn 5W30 with a mobil 1 filter(autozone hand a special...5 quarts and a filter for 25.99)
Old 07-15-2008, 02:34 PM
JDM EJ2's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Both on my D16Z6 (I/H/E) and my D16Y8 (I/H) I run/ran Mobil 1 fully synthetic 10w30 (green!) with an autozone filter.
EDIT:
I don't use additives to make it last longer, or seafoam, or any of that jazz - I also don't use the "5000 mile no change" line of Moibl 1 or whatever - I use the regular and change it every 3000.</TD></TR></TABLE>
I don't use the additive so I can make the mileage last longer, I still go 3 months, 3000 miles. I use it for that extra protection so I don't burn a ring or anything like that. It will actually clean out years of engine sludge after the first change... I just made sure I changed it a week or so after just using regular non-synthetic oil and sure enough, the darkness poured out. I'd recommend it to anyone
Old 07-15-2008, 02:38 PM
VTECth1s's Avatar
&lt;~~B18C1 bone stock; 10w30 Fully Synthetic Mobil 1
Old 07-15-2008, 02:40 PM
jdmdarksol's Avatar
Default Re: (sugarfree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sugarfree &raquo;</TD></TR><TR><TD CLASS="quote">castrol edge 5w30
Dam is that any good? don't think we have this in the US...
Old 07-15-2008, 03:22 PM
SarahVTEC's Avatar
Red Line 5W30
Old 07-15-2008, 06:53 PM
Bob Dole!'s Avatar
Default Re: What engine oil are you using? (SarahVTEC)
Bone stock z6 using mobil clean 5000 5w-30 with a wix filter. Changed ever 3000 miles. The oil was good enough to make help my z24 cavalier to 375,000 miles, when i sold it, i figured its pretty good stuff!
Quick Reply: What engine oil are you using?
