Battery was drained, jumped it, messed the battery cables up, now won't start.
Old 09-25-2009, 12:35 PM
quetzalcoatl's Avatar
Icon2 Battery was drained, jumped it, messed the battery cables up, now won't start.
I left my lights on so the battery was dead. Had my friend jump me and it started fine, but I accidentally removed the positive battery cable when removing the jumper cable, so the car died. Now it will crank but it won't turn. I tried prepping the fuel lines and checked the ECU fuse. I also tried removing the positive battery cable for about 90 seconds. The battery is fully charged at 13.00 volts, I have a multimeter.
93 D16Z6 Civic EX manual
Old 09-25-2009, 01:36 PM
Former User's Avatar
Default Re: Battery was drained, jumped it, messed the battery cables up, now won't start.
Is 80A fuse 41 blown?
Old 09-26-2009, 12:01 PM
smiff95's Avatar
See if the battery still has 12.something volts when the key is on. x2 on checking the fuses.
Old 10-01-2009, 09:44 AM
[IMG.]http://i639.photobucket.com/albums/uu115/RonJ_HT/picture_3636.jpg[/IMG]
I used my multimeter to check for continuity by touching one end to each metal leg/post on the top of each small fuse. For the larger fuses which were screwed down (80A 41) I touched the two screws holding it in. Is this correct? If so, all fuses under the hood and dash checked out okay.
I can hear the fuel pump prime, and when the priming ends I hear a distinct click. Does this mean the main relay is okay? What should I check next?
Old 10-01-2009, 09:45 AM
Battery has ~11.5, should be good.
Old 10-01-2009, 10:19 AM
EFbomb's Avatar
the 80a fuse you can see the wire inside, if its broke or burnt looking its probably bad.
Using the screws would be fine.
check the starter wires, make sure the solenoid signal wire didn't get bumped loose.
Old 10-01-2009, 02:55 PM
theBEST's Avatar
"reverse polarity" probably occured =pos. w/ neg. connected and vise versa w/ the neg. post when u jumped it. its all good 2 admit what u did wrong as it only helps us to help u out. ha ha and yeah inspect ur battery fuse which is located in ur uder-hood fuse box 80amp fuse screwed down w/ 2 philips screws either look at the visible strip or take it out since u have a multimeter and measure resistance (ohms) any reading means its not blown but no reading means open circuit/blown. hopes this helps...
niceprelude
17
12-26-2013 11:39 AM
mrsamsa
02-27-2013 09:59 PM
dc2teg2006
03-28-2009 05:31 PM
qbansir
07-13-2008 07:37 PM
4doorH22
11-27-2001 09:32 AM
Quick Reply: Battery was drained, jumped it, messed the battery cables up, now won't start.
