94 civic high idle
94 civic high idle
i got a 94 civic 5 speed manual just changed to 1.6 cylinder head and i have high idle any idea help would be appreciated and whats the proper wiring for oxygen sensors cause my 4 wires came out of the plug. thanks
Imperious: Mod of Valor
Re: 94 civic high idle (CycloneBlue_1.6EL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL »</TD></TR><TR><TD CLASS="quote">You're going to have to check everything over for vacuum leaks.</TD></TR></TABLE>
Yes, and how how is it idleing?
Re: 94 civic high idle (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">
Yes, and how high is it idleing?</TD></TR></TABLE>
its idle at like probably at 1000-1500 not sure cause i dont have tach. but by listening to the engine is sound like is at 1000-1500 any ideas and how do i check for leak and where thanks guys
Re: 94 civic high idle (civicpower94)
Check all the vacuum connections (there's not that many on a PGMFI Honda). You could take your intake off and seal your hand (or something) over the throttle body and see if it still runs, then you know you have a leak.
Re: 94 civic high idle (_Cyclone_)
alright i fixed the problem it was the idle control valve on the bottom of the trottle body, but i got another one problem . My rpms are going up and down i replaced the throttle body gasket cause thats where the leak was still doing the same **** up and down etc. i replace the eacv still the same **** any ideas. thanks
