Ball joint help
Ball joint help
I just got new ball joints put on and whenever I put the wheel all the way to the left or right and go then the joint makes this "POP" noise. Is this the ball joint or is it somethinge else?
Re: Ball joint help (drewlee)
I really dont think it should make any noise. Did you do it yourself, or have a shop do it for you? I'd recommend you either double check your work, or take to a shop to have it re-pressed into the control arm. The last thing you want is for that balljoint to "pop" out when your on the freeway or something.
Re: Ball joint help (import_racer_7)
Mine did that after I replaced them myself. I ended up wrecking the car before I got it checked out, lol. Don't know what it was but I didn't like that sound at all.
hawksftball2007
05-05-2015 08:24 PM
SIDreamer
02-24-2011 09:27 AM
allmotorpackage
Suspension & Brakes
10-24-2007 03:09 PM
SiRkid
12
06-09-2005 12:05 PM
