??Bad water pump sounds like??? - Honda-Tech
Old 06-18-2009, 05:25 AM   #1
misterknowbody's Avatar
Default ??Bad water pump sounds like???
I think my water pump died on me. Well I hope it's the water pump, the sound is coming from somewhere around there.
What does a bad water pump sound like on a 92 SI 1.6L SOHC?
misterknowbody is offline   Reply With Quote
Old 06-18-2009, 05:28 AM   #2
Default Re: ??Bad water pump sounds like???
bad water pump sounds like leaking antifreeze, and overheating.
bronx finest is offline   Reply With Quote
Old 05-24-2010, 04:44 PM   #3
Cogent Argument Enthusiast
Uncle Ben's's Avatar
Location: Completing my training with my Supreme Leader
Quote:
Bump. Can a bad water pump lead to coolant evaporation, if none is burned in the CC and is leaking from nowhere; intermittent overheating?
Uncle Ben's is offline   Reply With Quote
Old 05-24-2010, 06:51 PM   #4
Technical Hero
HondaPartsHero's Avatar
could be a small leak in the weep hole, that or your radiator has a hairline that's causing the leak but is evaporating off
HondaPartsHero is offline   Reply With Quote
Old 05-24-2010, 07:48 PM   #5
Quote:
You mean a 96-00 water pump will squirt water out if they're bad? Where would it go, if it's inside the timing cover?
I never thought about the radiator having a crack, but that might explain why the top of the radiator is dry, and it only takes like 1/8 a gallon to fill it back up. Either that or the water pump is doing nothing and coolant just sits in the bottom of the radiator/engine block lol.
water pump and oil pump brand? speedciv Acura Integra Type-R 11 05-24-2016 12:51 PM
Water pump replacment or bad timing belt? Barf Hat Acura Integra 1 04-04-2012 11:52 PM
2007 civic making loud clattering noise - water-pump bearing? billydekid Honda Civic (2006 - 2015) 4 07-18-2008 09:11 PM
Noise from water pump area!! Ge-money Honda Civic / Del Sol (1992 - 2000) 6 09-06-2006 03:55 PM
where's the water pump? DjNastyKnight Honda Accord (1990 - 2002) 5 07-07-2003 08:27 AM
Tags
16l, 2002, acura, bad, civic, failing, honda, intermittent, overheating, pump, rsx, sound, sounds, tsx, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
