BAD strut - Honda-Tech
BAD strut
Old 03-20-2008, 07:05 AM   #1
honda_ek9's Avatar
Default BAD strut
hey guys...gotta a noob question....i was wondering how much it would be to fix the bad srtuts...and what does it mean by bad struts.....thanks...
honda_ek9 is offline   Reply With Quote
Old 03-20-2008, 07:46 AM   #2
* B A N N E D *
Default Re: BAD strut (honda_ek9)
If you do the labor yourself than you could by struts anywhere from $100(stock) to $400(aftermarket). Indicators that struts are in need of replacement include a marked decrease in ride quality, changes in handling, play in the steering or uneven tire-wear. If any of these symptoms occur on your vehicle, it's a good idea to do a visual inspection of your struts to see if it may be time to replace them. Most struts are hydraulic, so check for signs of fluid leakage. Also check for visible damage to the outside of the strut's casing.
spivt11 is offline   Reply With Quote
will bad struts cause camber? shizkabob3421 Honda Civic / Del Sol (1992 - 2000) 9 03-06-2008 04:00 PM
strut replacement billyinse Honda Prelude 13 09-01-2007 12:38 PM
confirm/corect what i was told about bad struts... XxLuckyLisaxX Honda CRX / EF Civic (1988 - 1991) 7 09-01-2003 12:31 PM
KYB struts, good or bad? gsrhatch530 Honda Civic / Del Sol (1992 - 2000) 12 08-23-2002 11:15 AM
WTB : Integra Struts BranzLS For Sale 7 08-10-2002 10:48 PM
Tags
2003, accord, bad, civic, honda, integra, noise, signs, strut, struts, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
