Bad slave cylinder or clutch master cylinder?
Old 12-10-2013, 07:30 PM
Shit Posts: 15
JDMswagSerf's Avatar
Default Bad slave cylinder or clutch master cylinder?
I have a 97 civic and the clutch won't hold.
The pedal sinks down to the floor
I'm gonna replace whichever part is broken
But how can I tell if it's the slave cylinder or cmc?
If fluid comes out of the slave cylinder bleeder screw and pedal still sinks is it a bad slave cylinder?
And if fluid doesn't come out of slave cylinder bleeder screw but fluid disappears. Is this a bad cmc?
Old 12-10-2013, 07:41 PM
Former User's Avatar
Default Re: Bad slave cylinder or clutch master cylinder?
Is there fluid leaking from the clutch master cylinder at the top of the clutch pedal?
Old 12-10-2013, 07:53 PM
Shit Posts: 15
I haven't checked. Just got the car but asking so when I work on it in a while I know what to do and what to mark as broken
If there is fluid up there by the clutch pedal or any mess, a bad cmc?
Old 12-10-2013, 07:58 PM
yes
Old 12-10-2013, 08:00 PM
Koko4's Avatar
If there's fluid leaking into the pedal area, then master cylinder is at fault. Have you tried simply bleeding the system? You may just have an air bubble.
I replaced both of mine (master and slave) because it was only like $40 total, and mine would engage the clutch, then I'd be sitting still at a stop, in first gear and then BAM - it would disengage the clutch! I'd try bleeding it first though just to rule that out. There is also an adjustment screw to adjust the free-play in the pedal, which could be out of whack maybe?
Old 12-10-2013, 08:48 PM
Shit Posts: 15
Thank Ron. Will check that
And koko
Previous owner said he pumped the pedal with his friend. But at this point idk if he literally just pumped it and didn't open the bleeder screw lol
I'll try bleeding it just incase before I switch Anything
And 40$? From where
Old 12-10-2013, 08:51 PM
Shit Posts: 15
Oh and if I the cmc looks clean and no fluid is down there
Either leak in a line or bad slave?
Does anyone know if b and d series slaves are the same?
I know the fitting is. But the mounting point?
I have a good b series slave culinder
Old 12-10-2013, 09:47 PM
Shit Posts: 15
Just looked up part numbers
Slaves are interchangeable!! Whoooo
92eg6lsvtec
05-20-2006 05:56 AM
itsJDMyo
10-24-2005 05:02 PM
714JDMBB4
08-29-2005 05:34 PM
aengnr1
06-16-2003 12:23 PM
3rdGteg
11-05-2002 01:21 PM
Quick Reply: Bad slave cylinder or clutch master cylinder?
