is it bad that my car runs too cold??
Old 02-21-2009, 08:26 PM
umair's Avatar
Default is it bad that my car runs too cold??
i got a h22a swap in my del sol and when it is cold outside my temp needle does not even move. if i drive it for at least 30 min it will go up but it wont even get to the first line. i read somewhere that sometimes its bad when your motor runs too cold but many people say that its good that you motor runs cool. a few weeks ago it was in the 60s and i took my car out and the temp did go to the halfway point but my car felt a lot slower(it should). i know its good if your motor runs cool but my motor runs a little bit too cold, lol. is it anything thats wrong or is it a good thing??
thanks
Old 02-21-2009, 08:30 PM
Former User's Avatar
Default Re: is it bad that my car runs too cold??
It's not good for the engine to run cool. The ECU will force the engine to run in a preprogrammed mode that uses excess fuel (rich). Replace the thermostat because it seems to be stuck open.
Old 02-21-2009, 08:56 PM
umair's Avatar
do you think it is affecting the performance of my motor too???
Old 02-21-2009, 08:58 PM
Yes
Old 02-21-2009, 09:00 PM
lcsej1's Avatar
the computer will see your car as if it was warming up so itll run a special start up program like ronj@ht said. if it's cold it won't achieve stoichiometric(perfect air/fuel mixture.
Old 02-22-2009, 12:04 AM
Drsexiestboy's Avatar
I have the same problem but with a b16a would this also cause vtec to open very low...
Old 02-22-2009, 12:29 AM
hoffmanb16's Avatar
also get a aftermarket temp gauge, way more accurate.
79powerwagon
16
12-27-2010 09:25 PM
Hondaciv95VX
20
12-05-2005 01:41 PM
red91sit
01-10-2005 06:48 PM
machine4321
12-04-2003 06:34 PM
Boostless97Lude
01-11-2003 09:53 PM
Quick Reply: is it bad that my car runs too cold??
