Bad Battery affecting alternator while on driving?
Old 05-02-2005, 11:36 AM
Slammed Ek9's Avatar
Default Bad Battery affecting alternator while on driving?
So i found out i had a bad battery and i changed it today. would it be possible that while im driving on the road a bad battery causes not to charge my alternator therefore causing my car to low idle and die sometimes. my lights are also dim so i think thats the cause. does anyone have a clue what else it could be. thanks in advance
Old 05-02-2005, 11:54 AM
sadangryboi's Avatar
everything runs off your alternator after u start ur car...the only thing ur battery does is it gives juice to ur start allowing everything then to be powered by the alternator
check ur allternator belt and tension
Old 05-02-2005, 11:59 AM
B2FiNiTY's Avatar
Default Re: Bad Battery affecting alternator while on driving? (RaceMyHatchBack)
Sounds like a problem with the alternator.
Old 05-02-2005, 12:06 PM
PLAN:B's Avatar
Default Re: (sadangryboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sadangryboi &raquo;</TD></TR><TR><TD CLASS="quote">everything runs off your alternator after u start ur car...the only thing ur battery does is it gives juice to ur start allowing everything then to be powered by the alternator
check ur allternator belt and tension</TD></TR></TABLE>
and also check the 10mm connection on the top (of the alt.) under the rubber cap.
tkda
29
05-05-2009 02:46 PM
C-A
10-01-2007 07:17 PM
EG6R
05-10-2007 01:57 PM
mymeatb18"
08-15-2006 10:35 AM
Acura EL
10-12-2004 04:01 AM
Quick Reply: Bad Battery affecting alternator while on driving?
