b20vtec oil feed
Old 03-05-2008, 06:16 AM
Banned
stevew84's Avatar
Default 97 ek hatch b18 leak problem
i got a b18 head with b20 block. anyone have the oil feed line on this motor leak? every time i rev the engine i get oil spitting out by the filter (where the bottom end of the oil feed line is). for about 30 seconds oil was pouring out like a faucet and the oil was muddy looking. like when u take the oil pan off. any suggestions for this type of leak?
also there is an LS throttle cable on this motor which is about 6-8 inches too long. very low idle and accelerator gets stuck from the cable drag i guess. any suggestions? oh i forgot, im not sure which ecu to use for this i know its an obd1 but any certain one? whats the point of vtec if the car wasnt factory programmed for it.
any help will be appreciated
**90 ef hatch for sale**
Modified by stevew84 at 7:30 AM 3/5/2008
Old 03-05-2008, 07:17 AM
Resident Gearhead
BryanM.'s Avatar
Default Re: 97 ek hatch b18 leak problem (stevew84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevew84 &raquo;</TD></TR><TR><TD CLASS="quote">(1)<FONT COLOR="red">i got a b18 head with b20 block. anyone have the oil feed line on this motor leak? every time i rev the engine i get oil spitting out by the filter (where the bottom end of the oil feed line is).</FONT> for about 30 seconds oil was pouring out like a faucet and the oil was muddy looking. like when u take the oil pan off. any suggestions for this type of leak?
(2)<FONT COLOR="red">also there is an LS throttle cable on this motor which is about 6-8 inches too long. very low idle and accelerator gets stuck from the cable drag i guess. any suggestions?</FONT>(3)<FONT COLOR="red"> oh i forgot, im not sure which ecu to use for this i know its an obd1 but any certain one? whats the point of vtec if the car wasnt factory programmed for it.</FONT>
any help will be appreciated</TD></TR></TABLE>
(1) Inspect the line carefully for breakage, make sure the gasket from the previous oil filter is not sandwiched between the newer filter and the block. Fram filters are infamous for this.
(2) Get a GS-R cable.
(3) GS-R's come with the P72 ecu, IIRC VTEC is set at 4400 rpm. Even though you have a B20 bottom end think of it as B18C ecu wise.
Mc
Old 03-05-2008, 08:31 AM
Banned
stevew84's Avatar
thanks man i will update as soon as i look into this.
4tika4
02-03-2012 02:27 PM
Evilparadize
03-08-2008 08:19 PM
stevew84
03-05-2008 08:29 AM
nominous
10-17-2003 08:06 PM
turbotypeR@SPEC
09-08-2003 02:27 PM
Quick Reply: b20vtec oil feed
