b18c1 white smoke not head gasket - Honda-Tech
Old 01-06-2011, 07:04 AM   #1
Default b18c1 white smoke not head gasket
i have a 1994 honda civic coupe with a gsr swap ab a 95 on the engine ive been having alot of problems first blowed head gasket then rod bearings then a few small problems .
Ok so i had head resurfaced port & polished new valves just bc i thought that would be good replaced all the rod bearings, new water pump new plugs, wires ,new tstat new alum. rad. and new rings
ok so all back together still have a oil leak on the front left hand side of the head dont like that also car is smoking white out the tail pipe like cold smoke but its not that also i let it run last night for almost a hour checked the coolant and it doesnt seem to be flowing water to me rad. gets hot top hose gets hot bottom hose cold temp looks fine on car . no cels all hoses should be in the same place i double checked them . do have a small water leak but its just a clamp not tight on the back of the intake i think any help would be great .
hondaboy9506 is offline   Reply With Quote
Old 01-06-2011, 05:55 PM   #2
95ProjectEJ1's Avatar
Default Re: b18c1 white smoke not head gasket
Possible thermostat for the cold lower hose IMO.
As for the oil leak on the left side maybe the VTEC solenoid? Cam seal plug? VC gasket did seal all the way or?
How long has the car sat? Maybe the smoke is just condensation?
Shitty ideas, but a start I guess
95ProjectEJ1 is offline   Reply With Quote
Old 01-06-2011, 06:57 PM   #3
so you have white smoke out of the exhaust, no water flow, and your car doesnt over heat? is the bottom hose cold or cooler then the top? and what are the other small things?
luvinlife is offline   Reply With Quote
Old 01-06-2011, 08:53 PM   #4
D3vin's Avatar
As for your oil leak issue. It could be your vtec solenoid. I have that problem with my B18, gasket maker that **** and it stopped leaking. Awaiting to buy new gaskets.
D3vin is offline   Reply With Quote
Old 01-06-2011, 09:30 PM   #5
-__-'s Avatar
They are right about the thermostat. its probably installed wrong or not opening up. hows ur water pump? also oil leak on the front left side of the head could be distributor o-ring, vtec solenoid gaskets or valve cover gasket.
-__- is offline   Reply With Quote
Old 01-07-2011, 05:06 AM   #6
no the oil is not leaking from the vavle cover or the vtec solenoid it from the head gasket on the front left corner like it didnt seal good but thats crazy did everthing to specs and bought a pretty good gasket felpro msl gasket the other small things that was wrong was the valve need adjusting i did that also tho just lil stuff talked to a guy last that has been working for honda for like 25 years he told me to drive it for at least 15 mile and see if it quit smoking but it did not so any more advice would be great
Old 01-07-2011, 06:03 AM   #7
b16vt3c's Avatar
remove the thermostat & see if it will keep smoking if it stops then it is the thermostat thats went bad
b16vt3c is offline   Reply With Quote
Old 01-07-2011, 06:04 AM   #8
ok ill try that tonight and see
Old 01-07-2011, 08:39 AM   #9
rickkane's Avatar
The lower rad hose should b cooler than the top hose. If your not overheating, and its actually smoking, then its got NOTHING to do with the thermostat. How did u break in the new rings/motor? Also is the oil leak on the trans side?
rickkane is offline   Reply With Quote
Old 01-07-2011, 10:10 AM   #10
Quote:
the same thing has happened to every b series motor ive owned. its just something they do. and yes it is leaking from between the head and the block. i have an multi layer steel headgasket and it does it on my car too. one way to fix it is to take the head off and use silicon or gasket maker on that corner. but i just leave mine because it isnt worth the hassle for how small the leak actually is
93egctr is offline   Reply With Quote
Old 01-07-2011, 11:46 AM   #11
the bottom hose is way cooler than the top hose like not hot at all to the touch i broke the rings in by driving it very mild until i hit 800 miles then i got down on it some thats when it started knocking but it was a rod bearing i replaced those all of them that seem to be fine now . and yes the oil leak is on the trans side for rickkane questions.
and yes i know that most b series leak there but mine seem to be a lil worse than i thought it would but this is a brand new gasket head redecked so it should not be i guess the way i feel is it didnt leak from the factory so i dont want it to just looks bad just me i guess
Old 01-07-2011, 12:18 PM   #12
90_EX_Civic's Avatar
did you hone the cylinder walls before replacing the rings? i've heard from a couple of honda technicians that if you don't hone it, you'll smoke.
90_EX_Civic is offline   Reply With Quote
Old 01-07-2011, 12:28 PM   #13
for the leak i had the same issue, did a new head and valve cover gasket and arp head studs.. i think the arp studs helped the seal over the stock ones. if you dont have those, id give them a shot.
dfJDM is offline   Reply With Quote
Old 01-07-2011, 01:31 PM   #14
yea i would like to get the arp head studs just because but i dont think they will help seal the head to block but they might . yes i honed all the cylinders but i dont think they needed it they looked great
Old 01-07-2011, 01:49 PM   #15
-__-'s Avatar
im pretty sure your OIL leak isnt from your headgasket...otherwise coolant would be coming out? idk lol
the oil is probably just GATHERING at that point. check for oil coming from a higher place. its probably just dripping down and settling there. Distributor o-ring
Old 01-08-2011, 12:03 PM   #16
rickkane's Avatar
Distributor o ring is likely the issue.
Old 01-08-2011, 06:42 PM   #17
Take some CLEAR, DETAILED pics for us and lets us see the leak. Try and clean the area off.
1995 Accord Coupe head problem shinobiu Honda Accord (1990 - 2002) 2 11-29-2016 06:45 PM
blow hg or waterpump failed joytjuhhhh Tech / Misc 7 10-05-2015 08:04 PM
Overheating problem zereda Honda Civic / Del Sol (1992 - 2000) 2 05-28-2015 02:40 AM
Mild built ls/vtec overheating issue? 91boostedb2o All Motor / Naturally Aspirated 7 07-29-2009 01:31 PM
Cooling issues RRRex Tech / Misc 2 08-19-2003 06:55 AM
Tags
92, b18c1, cam, civic, gsr, leak, oil, plug, series, smog, smoke, smoking, swap, vtec, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
