b18b1 swap in eg6 motor mount ??s
Old 04-14-2011, 12:36 PM
xxEG6xx's Avatar
Default b18b1 swap in eg6 motor mount ??s
Ok im doing my first ever swap ls motor and tranny.
Ill will be useing this as i go looks preaty easy.
http://forums.tunedtech.ca/f21/b18c1...hback-178.html
Now heres my ?? What motor mounts do i need bcuz the swap that i got it didnt come with motor mounts please help this is the only thing thats holding me back form doing the swap.thanks for looking guys and if you have any of those parts lmk ill buy.them off u
Old 04-14-2011, 05:22 PM
xxEG6xx's Avatar
Default Re: b18b1 swap in eg6 motor mount ??s
Any one
Old 04-14-2011, 06:51 PM
phaphon's Avatar
i used my stock eg mounts just to get it going but you can also upgrade to integra(94-00) mounts
Old 04-14-2011, 07:24 PM
xxEG6xx's Avatar
so ur saying i can use my eg mounts even the t bracket?
Old 04-14-2011, 07:38 PM
phaphon's Avatar
sorry i didnt know you meant t bracket too you have to use the 94-00 integra bracket
Old 04-15-2011, 11:24 AM
Smex26's Avatar
u can use ur eg mounts bro. u have to get a diff. T bracket tho. make sure its not the braket from an older teggy. 94-00 should be fine. as far as the tranny mount, i think u might need a b series mount. im pretty sure its diff than the sohc tranny mount.
Old 04-15-2011, 12:14 PM
Seagull Management
94EG8's Avatar
Upper mount is the same, front lower bracket is different though.
Old 04-15-2011, 12:30 PM
xxEG6xx's Avatar
Ok so here is what i got i can use my stock mounts but need a new t bracket along with rear mount and tranny mounts.
Old 04-15-2011, 12:32 PM
Seagull Management
94EG8's Avatar
You can reuse the stock rear mount, if you're going to replace it buy one for an integra though, they're stronger. you will need a driver's side mount as well unless you happen to have an aluminum driver's side mount ('94 - '95 VX/EX/Si)
Old 04-19-2011, 08:30 AM
phaphon's Avatar
when i first did my b16 swap i used a stock eg mount and it was not the aluminum one but its recommended since the single one wont be strong enough
Old 04-19-2011, 02:40 PM
Seagull Management
94EG8's Avatar
They're strong enough. B16As all had that black stamped steel mount from the factory, it was only the Integras and for whatever reason '94 - '95 D-series Vtec/Vtec-e Civics that got aluminum driver's side mounts.
Old 04-24-2011, 03:54 PM
Smex26's Avatar
use ur stock mounts for now. just switch ut bracket.
my bro in law spun a rod in my engine and broke the block! i need another block asap.... anyone know of a good used block at a decent price? b20 prefered but b18 will due.
anzh86
07-23-2010 09:20 PM
hondaEg_808
12-02-2008 01:51 PM
Civic2Fast
05-23-2008 07:55 AM
95hatch
10
09-23-2003 08:21 AM
roc109
01-08-2003 01:46 PM
Quick Reply: b18b1 swap in eg6 motor mount ??s
