b18a1 swap into 97 civic - What axles?
i am in process of finishing up my b18a1 swap in my 97 civic and i was wondering if i can use the da b series half shaft and axles
Re: b18a1 in to a 97 honda civic
Your gonna need 94-01 axels and halfshaft If I remember correctly the DA driver side axle is shorter and the DA halfshaft doesnt work right with the hydro trans.
Re: b18a1 swap into 97 civic - What axles?
sum da are hydro 91 thru 93 and thats what it came out of i did some research and it says the obd1 da the axles and half shaft will work only difference is the male and female ends are different than the dc on the driver side there backwards from the dc but thanks for your help man
Seagull Management
All DAs use a cable tranny. You can use the axles and intermediate shaft as a set though, but you will need the driver's side axle seal for a '90 - '93 Integra.
jdm_vtec
08-30-2007 11:57 AM
