B18a1 in Ek Vacuum Lines ?
Anyone have a diagram for how the vacuum lines should be ran? The motor is in an EM1 but i'm running obd1 now so alot of things are deleted such as charcoal canister and evap.
So if no one has a diagram..where do the two lines off of the IAC connect to? From the nipple right above the waterneck and the water pipe?
Re: B18a1 in Ek Vacuum Lines ?
If you have a fiav under throttle body then coolant pipe to iacv nipple closest to driverside then other nipple on iacv to back nipple of fiav then from nipple of fiav to intake manifold nipple close to head where bolts in pasg upper side. If you deleted fiav then from iacv pasg side nipple to intake nipple
That was sorta confusing Grant. haha
I have no fiav on the TB. I did some reading but idk what to believe. I read the coolant line with the nipple right above the waterneck connects to one port on the IAC and the other port on the IAC goes into the water piping. True or false?
Vagitarian
23
10-21-2012 08:27 PM
B18 CYA
09-27-2006 08:20 PM
b18a1, connecting, connection, connections, diagram, ek, h22, hose, hoses, line, lines, pipe, vaccum, vacuum, water
