B18 swap in ek throttle body question
So I did a swap on my EK with a B18b. As I was changing the throttle bodies over, I noticed that one of the pin plugs on the throttle body is 2 pinned. All the wiring from the EK that went on the d16 throttle body is all 3 pins. Should I ignore it? The d16 throttle body works on the B18, but I want the B18 throttle body cause it's bigger.
1 Post
Re: B18 swap in ek throttle body question (chineseflyrice)
there should only be 2 things on the TB the map and the TPS, both can be switched from the old TB if there any problems, but there should not be.
oh, I see what you mean. there's another part that's connected to the throttle body, oh, it's the VALVE ASSY., ELECTRONIC AIR CONTROL. There isn't one on the D16, but there is on the B18, does anyone know where this plugs into?
