B16A2 POWER STEERING AND A/C
Old 10-14-2009, 04:20 PM
XhaloZ's Avatar
Default B16A2 POWER STEERING AND A/C
Old 10-15-2009, 03:48 AM
XhaloZ's Avatar
Default Re: B16A2 POWER STEERING AND A/C
Old 10-15-2009, 05:50 AM
Smarg's Avatar
You could ask over at Honda Heaven in Kennendale.
Old 10-15-2009, 07:01 AM
willywonka514's Avatar
Bummmppppp . They single cam ps pump and bracket wouldn't fit . And the ac bracket is diff . You will need a b16 ps pump and bracket and ac bracket for a b16 and the pressure hose will fit no problem but it has to a p2t which is a 99 or 00 si pump . I had the same problem on my hatch ight
Old 10-15-2009, 07:03 AM
ekhatchnasty's Avatar
U CAN USE THE AC BRAKET FROM A CRV
Old 10-15-2009, 09:02 AM
XhaloZ's Avatar
Old 10-15-2009, 09:04 AM
XhaloZ's Avatar
Old 10-15-2009, 09:23 AM
XhaloZ's Avatar
Old 10-15-2009, 09:36 AM
IF U CHANGE JUST THE BRACKET U CAN USE THE STOCK AC COMPRESSER
Old 10-15-2009, 09:50 AM
kaduku_'s Avatar
i have a power steering pump with one hose and bolts and bracket same with the ac compressor but i live in Cali, oh yeah and i have the belts too. all came off of a 94 Sir2 with low miles.
Old 10-15-2009, 09:55 AM
XhaloZ's Avatar
Old 10-15-2009, 10:07 AM
Jimster480's Avatar
ok. You would tell them the model year of your motor. So you would say 99Si. But you can use a CRV AC bracket, because a CRV motor uses a D series AC Compressor. The hoses will fit fine. And yes you should be able to use a P72 P/S pump.
Old 10-15-2009, 10:09 AM
kaduku_'s Avatar
im not 100% sure on this but any 94+ integra, the del sol v-tec or 99-00 Si should work just fine. Im not sure on the b18c's but i think all b16's and b18a/b's have the same mounting spots.
Old 10-15-2009, 10:10 AM
kaduku_'s Avatar
wow i didnt know that. im hooking up my ac back up then. Thanks brah.
Old 10-15-2009, 10:26 AM
Jimster480's Avatar
ya np. A/C is win.
Old 10-15-2009, 11:33 AM
XhaloZ's Avatar
Old 10-15-2009, 03:36 PM
Jimster480's Avatar
I you need the GSR High Pressure hose. You can use a B16 one, idk if the other ones are the same.
Old 06-05-2010, 09:55 AM
tonySem's Avatar
Im going through the same thing... I want my AC and P/S...
Old 06-05-2010, 12:31 PM
Corksil's Avatar
In my understanding, all B-series externals are the same.
If it's b-series, it will bolt up to b-series. b16,18,20... shouldn't matter.
I think p72 and pr3 are b-series part numbers. you can look on majestic honda or hondapartsunlimited to find the parts, drawings, and part numbers you need to know to get the right components.
i would recommend you do your research, find out what parts you need, then go to the local store and tell them the year of your motor. then take the part out of the box and look at it. if you research things, you should know what it looks like and what markings are on it. double check.
Old 06-06-2010, 09:33 PM
Jimster480's Avatar
P72 is a GSR ECU. PR3 is a head code (idr which one off the top of my head).
And they are not all the same. B20's use D series AC compressors with different brackets. And I think it might have a different power steering as well (not sure about that though).
Old 03-30-2014, 09:56 AM
pilon33619's Avatar
Ever figure it out..
What brackets with the p72 ps pump
r1whore
09-10-2008 01:30 PM
T3k C
11-16-2006 06:33 PM
RACEPAK
07-11-2005 04:04 AM
Quick Reply: B16A2 POWER STEERING AND A/C
