b16a2 bogging?
Old 01-29-2009, 11:30 AM
goldfinger93030's Avatar
Default b16a2 bogging?
so i did a b16a2 swap into a 98 civic and it runs on a p28 ecu at the moment it drives and doesnt die at the idle but every once ina while the idle drops down and jumps up for a little bit of time, then sometimes when street driving, if i give it gas it makes a puttering noise and doenst really accelerate, and then all of a sudden will take off like if there was no problem again. i am not getting any check engine lights either.
Old 01-29-2009, 11:46 AM
lovelove's Avatar
Default Re: b16a2 bogging?
isnt a p28 chip for a single cam vtec car only? im pretty sure it is. however, why put it with a b16? shouldnt it run with a p30 chip? or unless you can chip it because the computer isn't throwing enough fuel for your motor. its only throwing enough fuel for the single cam and its thinking that your motor is a single cam.
Old 01-29-2009, 12:02 PM
so if i chip the ecu and run the right one that should fix the problems. is it bogging out cuz there isnt enough fuel going to the motor?
Old 01-29-2009, 12:05 PM
keving85's Avatar
i would start with the right ecu and then work from there.... the 8-ball reads :try new ecu;
haha i got a mechanic's version of that 8-ball: fixed many of cars.... lmao
OH and no flame intended.... just fun
Old 01-29-2009, 12:07 PM
93egSLEEPER's Avatar
the p28 ecu is one of the best ecu's to use with almost any motor for tuning. you need it chipped with a b16 base map and tuned for the mods you have on your car. i had a jdm b16 chipped and tuned on crome and it worked very nice
Old 01-29-2009, 01:47 PM
honda305's Avatar
whats the difference between a po6 chipped and a p28 chipped?
Old 02-02-2009, 06:57 AM
lovelove's Avatar
well, yeah just either chip it or get another ecu?
Old 02-02-2009, 07:23 AM
kp
kp's Avatar
Different ECU's.
Old 02-02-2009, 09:23 AM
DC2-ProdUcTiOnS's Avatar
Location: Howcome we park on driveways, and drive on parkways?
I have a mild build B16 with a P28 ECU as well. I had mine chipped by Kenji.
def could be your problem because when i first used the P28 it had a all motor fully built GSR chip in it. One call to Kenji with my list of mods, and the difference was noticeable instantly. Still had to do some minor tuning and adjustments of course but def check this out...
Old 02-02-2009, 09:41 AM
joelmatt89's Avatar
I have a b16 with a p28 chipped and it runs really good, if your looking for someone to chip yours phearable.net is really good and they will do it for you for $75 just ship it to him and you will have it back in a week or you can buy one chipped from him for $175. But like some others said a p28 is a great ecu you just need it chipped to run the b16 and then it should work fine. By the way just to check you should know that you need to put a resistor on for your injectors if you are running the stock b16 injectors, if you didn't your ecu could/will be fried.
stackedhouse
Engine Management and Tuning
05-30-2012 03:50 PM
Revolution2zz
08-10-2006 07:52 AM
1truelovedstd
12
07-28-2005 09:26 AM
ALLMOTA92EG
04-11-2005 12:58 AM
.(Lazarus).
09-04-2002 11:15 PM
Quick Reply: b16a2 bogging?
