B16A 99 Civic Si FAILED SMOG
Old 03-22-2012, 04:34 PM
Si818's Avatar
Default B16A 99 Civic Si FAILED SMOG
What's up everyone,
I'm new to the site and I live in North LA. I just took my car to the smog shop today and I failed the
-NO (PPM) 15mph Mine read:1952 and max is 487 @25mph
-NO (PPM) 25mph READ: 1811 max: 774 @ 25mph
-HC (PPM) 15mph read: 116 max: 66
-HC (PPM) 25mph read: 27 max: 49
Could anyone please help me figure out what's wrong? Or why they measured like this.
Old 03-22-2012, 05:33 PM
CaliforniaSi's Avatar
Default Re: B16A 99 Civic Si FAILED SMOG
How many miles on the engine? What mods do you have on the car? Are you in northern Louisiana or North Los Angeles?
Old 03-22-2012, 06:38 PM
Si818's Avatar
DC headers, aem short ram intake, blox cams, gears. 110,000 miles. North Los Angeles
Old 03-22-2012, 06:40 PM
jst2878's Avatar
did you ever change your o2 sensors or pcv valve. your rings could be shot
Old 03-22-2012, 07:35 PM
Si818's Avatar
o2 sensor seems fine, no CEL on and it. Going to check the pcv valve soon, just need to google how to see if it works. I've been reading and it could be that I have an exhaust leak right before the cat, I took out the donut and haven't replaced it.
Old 03-22-2012, 11:07 PM
Edwin209's Avatar
mine wont pass with my intake on i either pay more for a cricked one or just take a diff intake try that out maybe it will work for you or just look for a smog shop to pass it cricked they charge more but sometimes u just have 2 do it
Old 03-22-2012, 11:46 PM
Si818's Avatar
how much am i looking at? you from modesto?
Old 03-22-2012, 11:49 PM
jbpnoman's Avatar
When was your last full tuneup? Plugs, wires, cap, rotor, oil, PCV, air filter clean, timing check?
Old 03-23-2012, 07:54 AM
Arthas's Avatar
Cricked? You are from Modesto, CA lol..
Could the cams be affecting his emissions?
Old 03-23-2012, 09:41 AM
Si818's Avatar
The cams are not affecting the emissions from what my mechanic told me and It has new plugs, sparks, cap, rotor, fresh oil change but I do need to check the PCV and timing. Do you guys think it's the donut right before the cat causing this?
Old 03-23-2012, 08:29 PM
svthoser's Avatar
your o2 sensor does not have to throw a CEL for it to be reading incorrectly
Old 03-23-2012, 09:18 PM
jbpnoman's Avatar
Yes, not having a crush gasket in the exhaust can cause problems, especially if your crush gasket is near the O2 sensor. The air mixture from the leak can royally mess up the AFR's your ECU sees.
Old 03-23-2012, 09:28 PM
famous323's Avatar
check ignition timing
Old 06-09-2012, 07:55 AM
turtleef's Avatar
did u ever get the prob fixed? 02 on a obd2b will catch a lazy bank 1 n bank 2 o2 when u get a bank 2 02 code its sign of a bad cat but if u hav no codes n ur Co levels are okay check ur spark make sure u use Honda aftermarket doesnt cut it with hondas! also do a carbon valve cleaner lik a seafoam or vacuflush nox is igntion misfire or preignition caused by carbon build up on pistons n valves most the time and hc is mis bured fuel ur allowed to retard the timing 2degrees from 16 so try that it might bring hc down but check vacume leaks n spark good luck
Old 06-09-2012, 09:05 AM
beecee18's Avatar
You have to be kidding me!
Old 06-09-2012, 09:10 AM
beecee18's Avatar
uhhhhhh this should have been the second post to this thread period!
Old 06-09-2012, 09:11 AM
beecee18's Avatar
change mechanics pronto!
My_EFsedan
08-08-2011 02:11 PM
tico
03-03-2011 02:10 AM
alexisthemovie
04-08-2007 07:56 PM
sf@rx7
11-18-2005 06:46 PM
ITR41
07-24-2002 11:15 PM
Quick Reply: B16A 99 Civic Si FAILED SMOG
