B16 Tranny and Oil Capacities please - Honda-Tech
Old 03-04-2009, 02:36 PM   #1
Rok_Stok's Avatar
Default B16 Tranny and Oil Capacities please
I need the manual transmission (transaxle if you want to get technical) capacity for a B16A, S4C in particular.
I need the oil capacity for a B16A. I've heard 4 quarts, I've heard 5, which is it?
This is all I need, thanks.
Rok_Stok is offline   Reply With Quote
Old 03-04-2009, 02:40 PM   #2
Mashimaro's Avatar
Default Re: B16 Tranny and Oil Capacities please
hey dood,
i think it should be 3.5-4 litres of oil for the motor (check the dipstick after 3.5 is poured in).
the tranny fluid should be about 2-3 bottles. fill it till it starts to come out of the hole
Mashimaro is offline   Reply With Quote
Old 03-04-2009, 02:44 PM   #3
EL Vap133's Avatar
Quote:
Originally Posted by Mashimaro View Post
hey dood,
Litres? Oh wait, I just saw that you're Canadian.
Here in the US it is about 3.5-3.9 Quarts. I usually pour 3.5 and then wait a while before I check the oil level to see if it needs more.
EL Vap133 is offline   Reply With Quote
Old 03-04-2009, 03:21 PM   #4
Rok_Stok's Avatar
Thanks guys. I primarily wanted to know the tranny capacity to know if I should buy 2 or 3 quarts, sounds like 3.
Old 03-04-2009, 03:47 PM   #5
SinsEvil666's Avatar
yea, buy 3. it takes about 2.5
SinsEvil666 is offline   Reply With Quote
Old 03-04-2009, 03:51 PM   #6
trustdestruction's Avatar
(US quarts)
engine oil:
engine overhaul capacity - 5.1 quarts
oil change with filter - 4.2 quarts
oil change w/o filter - 3.9 quarts
transmission:
overhaul - 2.4 quarts
drain/refill - 2.3 quarts
EDIT: fixed the tranny capacity, thanks jdm602
trustdestruction is offline   Reply With Quote
Old 03-04-2009, 03:54 PM   #7
Rok_Stok's Avatar
Where did you find the info on 2 quarts for the tranny?
Old 03-04-2009, 03:55 PM   #8
factory service manual
it's definitely believable... i know that a D-series manual tranny is also 1.9 quarts for drain/refill.
Old 03-04-2009, 03:59 PM   #9
Mashimaro's Avatar
Quote:
i used to work at an Acura stealership
Old 03-04-2009, 04:00 PM   #10
jdm602's Avatar
tranny is actually 2.3 us qts. per oil change. 2.4 for overhaul.
jdm602 is offline   Reply With Quote
Old 03-04-2009, 04:02 PM   #11
Quote:
correct
sorry about that... i was reading the D-series tranny stuff on accident.
my engine oil info is correct though.
Old 03-04-2009, 04:53 PM   #12
Rok_Stok's Avatar
Alright, 2.3 qts. Thanks.
Quick question: Do I use the D16 power steering pump on the B16?
Old 10-09-2009, 04:26 AM   #13
Dramysx's Avatar
I don't know if that will bolt up. You can try it though.
Dramysx is offline   Reply With Quote
Old 07-23-2010, 02:17 PM   #14
hi, how many quarts to fill a b16 automatic tranny? i just bought this b16a2 automatic swap and need to fill the tranny up. thanks
96 civic hatch is offline   Reply With Quote
d16y7 oil capacity? Irritated_Onion Honda Civic / Del Sol (1992 - 2000) 1 06-05-2008 05:39 PM
B16a coolant capacity water wetter Elwuudz Road Racing / Autocross & Time Attack 10 03-14-2008 10:07 AM
oil capacity? CeeJayy Honda Civic / Del Sol (1992 - 2000) 15 02-09-2007 06:04 AM
Quick one... whats the oil capacity of the 2.3 4ws prelude cookci Honda Prelude 1 04-26-2004 03:54 AM
b16a2 transmission oil capacity? yellowmonkeyboy Hybrid / Engine Swaps 3 06-28-2003 04:24 AM
Tags
1993, b16, b16a, capacity, change, del, drain, honda, lsd, oil, quarts, refill, s4c, sol, tranny
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
