B16 Timing Belt loose? (Video)
Old 03-31-2015, 02:53 PM
e0325's Avatar
Default B16 Timing Belt loose? (Video)
1993 civic hatch
b16a2, gsr trans, chipped p28, No Cel
I recently changed my timing belt (gates), water pump, oil pump, and tensioner all OEM. Car runs and drives fine, I just noticed that the timing belt seems to vibrate. Is this ok?
tensioner tight to 40lbs
Link to video
thank you
Old 03-31-2015, 04:49 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: B16 Timing Belt loose? (Video)
Did you follow proper tensioning procedure before torquing down the tensioner?
Old 03-31-2015, 05:11 PM
e0325's Avatar
I followed the guide found here:
How To Change Your B18C1 DOHC VTEC Timing Belt
Old 03-31-2015, 05:48 PM
White_EG1's Avatar
Uh, yeah your timing belt is loose. Please dont drive the vehicle untill you tighten it properly. Well unless you like skipped teeth.
Old 04-01-2015, 04:05 AM
e0325's Avatar
Thanks for info, I'll be redoing it this weekend
Old 04-01-2015, 05:29 AM
joey1320's Avatar
EASY, HONDA ACCORD & CIVIC TIMING BELT TIGHTENING TENSION PROCEDURE BOTH SIMILAR 96 ACCORD 2.2L - YouTube
please do NOT follow this guy's advice, he's not performing the install correctly. There's no reason for a person to have to add more pressure to the tensioner spring, unless you did something wrong, or didn't get a new one. What he is doing is actually worse, because he's adding more tension than called for and can cause premature wear of the belt or drivetrain.
If your belt is lose, it's because you didn't install it correctly. Please go over it again and make sure you have all the tension on the intake side of the engine and the slack on the exhaust side. Sometimes you may need to slightly turn the gears so that the tooth on the belt catches correctly and provides a high tension path.
Old 04-01-2015, 12:43 PM
tamboo's Avatar
riddle me this batman: why does the tensioner design allow overtightening to begin with? :hmmm:
Old 04-01-2015, 12:58 PM
White_EG1's Avatar
Hey I was just trying to help him out, couldnt find the helms article.
Old 04-01-2015, 04:10 PM
e0325's Avatar
Thanks for everyone's input. The exhaust side is tight but, the intake is really loose. So I'm going to pull the timing belt back off check the spring and tensioner, probably next weekend
Old 04-02-2015, 12:53 AM
NotARaCist's Avatar
Download yourself a factory service manual for your engine. Or, check my build thread. I go over the proper FSM-method for setting timing belt tension.
chahsiubow
12-14-2007 10:01 PM
civic_hatchback
06-10-2004 10:23 PM
Quick Reply: B16 Timing Belt loose? (Video)
