b16 sir 2 cams
1 Post
b16 sir 2 cams
i'm about to get some b16(170hp) sir 2 cams for my first gen b16
how can i tell if i'm really geting the right cams. is there any thing on the cam that can identify it as being the second gen b16 cams
how much more power can i expect? how much more hp?
i heard that the only reason the second gen b16 has 10 more hp is from the cams.
is this true? and if it is can i expect 10 more hp?
Re: b16 sir 2 cams (riceball777)
Quote: heard that the only reason the second gen b16 has 10 more hp is from the cams.
_______
It's also compression and ECU.
_______
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 »</TD></TR><TR><TD CLASS="quote">i heard that the only reason the second gen b16 has 10 more hp is from the cams.
is this true? and if it is can i expect 10 more hp?</TD></TR></TABLE>
No, a 2nd gen also has a larger TB (60 not 58mm) and higher compression ratio (10.4 not 10.2) so the cams will only make a small difference
Re: b16 sir 2 cams (SymphonyX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SymphonyX »</TD></TR><TR><TD CLASS="quote">save up money and buy civic type r cams... </TD></TR></TABLE>
