B16 head with a B20 block????
Old 04-02-2004, 08:37 PM
bonestock92si's Avatar
Default B16 head with a B20 block????
i have a b16 head that i am goin to do a swap with ... BUT im not sure what block would be best to use.. i was lookin into maybe a B20 but not sure what kinda compresion, HP, and tourqe i should expect or if there would be a better block to run instead.. any info would be helpful if anyone has done a b20 with the b16 head could u tell me what to expect and what kinda money i should look to spend in doin this swap..
Old 04-02-2004, 08:38 PM
Risky Business
BauleyCivic's Avatar
Default Re: B16 head with a B20 block???? (bonestock92si)
are you doing it yourself? can you build a motor?
Old 04-02-2004, 08:47 PM
hair_rice's Avatar
Default Re: B16 head with a B20 block???? (BauleyCivic)
could cost a little or a lot depending on your goals....you can just slap the head on the block and call it quits with just tappin it for vtec...or spend money and do it the right way which would be to get new internals, etc...just all depends on you man
Old 04-02-2004, 08:51 PM
Default Re: B16 head with a B20 block???? (hair_rice)
well i was goin to do a lil work prolly swap the pistons and do a port and polish the head.. other than that i know i want it to be able to hold a hearty shot of nitrous so what do yall suggest.. and if anyone knows of a good b20 block layin around let me know whats up with it
Old 04-02-2004, 10:14 PM
bump
Old 04-02-2004, 11:22 PM
JDMlyfestyle's Avatar
B20 vtec is a great motor setup if your going all motor. ive seen those pull like no others.
Old 04-03-2004, 12:10 AM
egtype-r's Avatar
Default Re: (JDMlifestyle)
get a gsr block with the b16 head and get b16b piston and a b16 lsd tranny
thats the way to go
Old 04-03-2004, 05:43 AM
Harassing Herbs's Avatar
Default Re: (egtype-r)
b20 walls kind of weak. sleeve it , do it right will hold anything u can throw at since your doing the pistons might as well do the rods too. don't want to half *** it have to rebuild like me. if you don't sleeve it your going to have to spend that money maybe more on the fuel management.
no sleeves means no room for error in tuning
Old 04-03-2004, 05:58 AM
HondaFanatic708's Avatar
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: (Harassing Herbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harassing Herbs &raquo;</TD></TR><TR><TD CLASS="quote">b20 walls kind of weak. sleeve it , do it right will hold anything u can throw at since your doing the pistons might as well do the rods too. don't want to half *** it have to rebuild like me. if you don't sleeve it your going to have to spend that money maybe more on the fuel management.
no sleeves means no room for error in tuning</TD></TR></TABLE> I would also sleave it. Maybe bump the bore to 2.2l and raise compression a little. It is an eternally disputed question: Which head flows better B16 or B18? I have heard alot of people go either way. But for your setup I would say B16. But WTF do I know, HPPY TUNING!
excivicboy96
10-14-2006 09:57 AM
bframe
03-07-2003 10:40 PM
Quick Reply: B16 head with a B20 block????
