B16 Distributor FSM procedure testing question
Old 05-05-2014, 08:21 PM
JasinC19's Avatar
Default B16 Distributor FSM procedure testing question
2000 Civic Si EM1
The car decided to die.
Traced no spark condition back to the igniter.
I am following the FSM procedure, but electrical work is not my strong point.
The FSM says to check for continuity between the BLU1 wire and the tachometer connector. Where is the tachometer connector? Is there only one wire going to it?
The FSM says that if the tests succeed, then replace the ICM. However, other sources say that the actual problem could be a crank position sensor malfunction. Should I test this before replacing my igniter?
I have one trouble code 61 for primary o2 sensor.
After the car died, I was able to start the car back up once, but as soon as I gave it a little gas, it died. Since then it cranks, but no start.
Thanks guys.
Jason
SVOHK
06-18-2015 08:46 PM
Jtkdirtbike
09-07-2013 06:47 PM
video_voide
17
05-13-2011 04:37 PM
90crxdxb16
11-21-2006 03:13 PM
the.hamburglar
07-29-2004 05:42 AM
Quick Reply: B16 Distributor FSM procedure testing question
