B16 cam seal - Honda-Tech
B16 cam seal
Old 03-01-2012, 04:12 PM   #1
Default B16 cam seal
i need to replace my cam seal
i have seen that you can just pry off the cap and replace it on the newer civics
can i do that on a b16 or do i have to remove the heagasket to replace it
BKJJ77 is offline   Reply With Quote
Old 03-01-2012, 04:18 PM   #2
D16SiHatch's Avatar
Default Re: B16 cam seal
The cam seal that's apart of the cam plug is i assume what you mean, not the cam seals behind the cam gears. You cannot pry it out, but no you don't need to remove the hg, why would you?
http://honda-tech.com/showthread.php?t=2414973
D16SiHatch is offline   Reply With Quote
Old 03-01-2012, 04:19 PM   #3
EK9
Dc4LsTeG's Avatar
You don't have to remove the headgasket..you have to take off the cam rail and cap
Dc4LsTeG is offline   Reply With Quote
Old 03-01-2012, 04:24 PM   #4
i got mixed up not the headgasket...im saying would i need to remove valve cover gasket to replace the cam plug
Old 03-01-2012, 04:25 PM   #5
Crazy Honda Guy
Deetz's Avatar
Quote:
Bingo!!
Deetz is offline   Reply With Quote
Old 03-01-2012, 04:26 PM   #6
EK9
Dc4LsTeG's Avatar
Yes you'd need to remove the valve cover
Old 03-01-2012, 04:26 PM   #7
D16SiHatch's Avatar
did you click the link!?
Old 03-01-2012, 04:27 PM   #8
or can i just pry it off like i have seen people do http://www.youtube.com/watch?v=kft_rAlFGe4
Old 03-01-2012, 04:29 PM   #9
EK9
Dc4LsTeG's Avatar
Are you listening to anything we are telling you?
Old 03-01-2012, 04:32 PM   #10
yah its just by the time i right a reply more people answer and then what i right dosent make sense
Old 03-01-2012, 04:32 PM   #11
so do i need to buy a new valve cover gasket
Old 03-01-2012, 04:42 PM   #12
EK9
Dc4LsTeG's Avatar
Yes
GSR camshaft seals replacement?? jdm b16 eg Acura Integra 14 09-22-2014 07:19 AM
Help with Cam seal 91EF919 Honda CRX / EF Civic (1988 - 1991) 12 08-31-2009 10:01 PM
D16Y8 cam seal ? alotawatts Honda Civic / Del Sol (1992 - 2000) 5 11-26-2004 05:44 PM
oil leak at cam seal? Specialk Tech / Misc 2 01-14-2003 08:50 AM
Cam Seal Replacement CHRIS 1.8 Honda CRX / EF Civic (1988 - 1991) 2 03-18-2002 07:43 PM
Tags
b16, b16a, cam, camshaft, cap, change, doesnt, location, placement, plug, replace, replacement, seal, seals, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
