b16 block, type r head?
Alright, someone i know has the stock 2000 si block with a type r head.. how could i tell if its really a type r head, and what is the numbers he should be putting down? has this ever been done, i mean im sure it has, but whats it called.. oh and is it possible to have your nitrous hooked up to your gas pedal so when you hit a certain rpm that the ntirous kicks in? just wannaknow if hes bullshittign or not.
Re: b16 block, type r head? (vlc92189)
An ITR head will have green paint near the distributor if it hasn't been worn off yet. An ITR head isn't much different from a B16 head aside from the cams, valvetrain, and PnP. He shouldn't expect totally huge numbers but a slight difference. It's called a head swap. Yes, you can hook up nitrous to kick in at a certain RPM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">An ITR head will have green paint near the distributor if it hasn't been worn off yet. An ITR head isn't much different from a B16 head aside from the cams, valvetrain, and PnP. He shouldn't expect totally huge numbers but a slight difference. It's called a head swap. Yes, you can hook up nitrous to kick in at a certain RPM.</TD></TR></TABLE>
What he said. Also, about the nitrous thing, it's either a window switch, which opens the N02 for a certain rpm - rpm, or a pill, which pens it at a certain given rpm
Modified by black_EM1 at 6:46 AM 6/21/2006
Modified by black_EM1 at 6:47 AM 6/21/2006
TurboEM1
12-26-2009 07:50 PM
