B series waterpump replacement.
Is there an easy way to replace a waterpump without having to remove the engine. Its a b16 in a del sol I replace everything except the waterpump gasket and it is leaking.
Re: B series waterpump replacement.
Kinda, To do it you would need to remove the harmonic balancer to take the lower timing cover off. Then after the cover is off loosen the belt tension, and take the 5 waterpump bolts out? Be careful when taking the bolts out there's 2 long ones and 3 short ones. Make sure you remember where they go.
nbcivic
02-06-2006 05:09 PM
