Axles for auto and manual 99 ex civic coupe
Old 12-28-2006, 08:44 PM
hypnotiqcivic99's Avatar
Default Axles for auto and manual 99 ex civic coupe
I have a 99 civic ex coupe and I am doing a auto to manual swap and need to know if I can re-use the auto axles..
Are they the same part number as the manual axles??
Old 12-28-2006, 08:51 PM
b18ctrb's Avatar
Default Re: Axles for auto and manual 99 ex civic coupe (hypnotiqcivic99)
The axles should be the same
Old 12-28-2006, 09:03 PM
Not to be rude but I don't want a should be. I need to know for sure and I have no way of finding out. Somone help. Thanks in advanced.
Old 12-28-2006, 09:29 PM
jtchinoy's Avatar
As long as your auto axels are in good condition, they should be fine. There's a c ring on the inside of each axel though. You're suggested to replace it after you pull the axels out of your a/t transmission Don't try to shortcut and put the axel in without the ring, the axel can pop out for no reason without the clip.
Old 12-28-2006, 09:30 PM
b18ctrb's Avatar
Default Re: (jtchinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtchinoy &raquo;</TD></TR><TR><TD CLASS="quote">As long as your auto axels are in good condition, they should be fine. There's a c ring on the inside of each axel though. You're suggested to replace it after you pull the axels out of your a/t transmission Don't try to shortcut and put the axel in without the ring, the axel can pop out for no reason without the clip.</TD></TR></TABLE>
Old 12-28-2006, 09:32 PM
jtchinoy's Avatar
oops i put should be I can't guarantee they're fine... you need your axels coming out fine and your transmission fine... both need to be D-series... after that it'll fit guaranteed
Old 12-28-2006, 09:35 PM
haveaniceday's Avatar
They work, Im 100% sure. Speak from experience.
Old 12-29-2006, 10:14 PM
Is this what I need to replace when I do it?
http://replacement.autopartswa...false
Old 12-29-2006, 10:26 PM
chrisw85's Avatar
Default Re: (hypnotiqcivic99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnotiqcivic99 &raquo;</TD></TR><TR><TD CLASS="quote">Is this what I need to replace when I do it?
http://replacement.autopartswa...false</TD></TR></TABLE>
http://www.slhondaparts.com/br...=true
part number 9, 44319-SR1-003 SET-RING (26X1.8) (GKN)
Old 12-30-2006, 06:47 AM
Which part is the c ring that I need?
Old 12-30-2006, 11:09 AM
Bump... need help.
Old 12-30-2006, 12:24 PM
Davis Photography
DrewMD's Avatar
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">
part number 9, 44319-SR1-003 SET-RING (26X1.8) (GKN)</TD></TR></TABLE>
he speaks truth. the axles WILL work. ive done it. replace the ring.
Old 12-30-2006, 12:28 PM
Default Re: (DrewMD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrewMD &raquo;</TD></TR><TR><TD CLASS="quote">
he speaks truth. the axles WILL work. ive done it. replace the ring.</TD></TR></TABLE>
I know to replace the ring but whats the part number or where can I get it?
Old 12-30-2006, 12:31 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnotiqcivic99 &raquo;</TD></TR><TR><TD CLASS="quote">Not to be rude but I don't want a should be. I need to know for sure and I have no way of finding out. Somone help. Thanks in advanced.</TD></TR></TABLE>
Well spoken.
Yeah they'll work.
Old 12-30-2006, 01:51 PM
I know to replace the ring but whats the part number or where can I get it?</TD></TR></TABLE>
Bump...
Old 12-30-2006, 06:37 PM
chrisw85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnotiqcivic99 &raquo;</TD></TR><TR><TD CLASS="quote">I know to replace the ring but whats the part number or where can I get it?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.slhondaparts.com/br...=true
Honda part #9: 44319-SR1-003 SET-RING (26X1.8) (GKN)</TD></TR></TABLE>
i like posted it up there dude.
tony n.
Honda Civic (2001 - 2005)
06-16-2009 09:54 PM
dannycraq
03-28-2008 12:29 PM
InfamousRS
05-13-2006 11:50 PM
blackZC (W)
12-30-2003 03:52 PM
InfamousRS
02-09-2003 03:57 PM
Quick Reply: Axles for auto and manual 99 ex civic coupe
