Axle nut thread size
Does anyone know the axle nut thread size for a 92 hatchback? I'm looking for the size in mm X pitch. I wanna buy titanium nuts for less unsprung weight.
Re: Axle nut thread size (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 »</TD></TR><TR><TD CLASS="quote">I wanna buy titanium nuts for less unsprung weight.</TD></TR></TABLE>
I honestly hope your kidding.
H-T Poker champion
What the expletive?
What the expletive?
Re: (ballerchild)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ballerchild »</TD></TR><TR><TD CLASS="quote">they're 32mm. someone correct me if i'm wrong.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 »</TD></TR><TR><TD CLASS="quote">Does anyone know the axle nut thread size for a 92 hatchback? I'm looking for the size in mm X pitch. </TD></TR></TABLE>
the thread size, not the socket size.
huh? how much weight are you going to save and how much money are you going to waste?
Re: (nonsense)
LOL...you people don't realise that Ti is HEAVY...its verry verry strong, allowing things to be made with LESS material making it lighter....but something like a nut, that needs to be a creatin size anyway...aluminium is way lighter then Ti....
btw, im not approving of your idea, i am merely laughing at your ignorance.
The nut is a 32mm but that is not the actual thread size
i.e. 10 mm head valve cover bolt is a 8mmx 1.0
what do you have against honda's nuts?
they work fine and I hope you dont care how they look get some center caps
Re: Axle nut thread size (Archidictus)
hmm, maybe everyone should just forget about what i need the thread size for and respond if you know the size and pitch only. i don't need the socket size.
Re: (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">LOL...you people don't realise that Ti is HEAVY...its verry verry strong, allowing things to be made with LESS material making it lighter....but something like a nut, that needs to be a creatin size anyway...aluminium is way lighter then Ti....
btw, im not approving of your idea, i am merely laughing at your ignorance.</TD></TR></TABLE>
by the way, you sir, are an idiot. don't ever question a mechanical engineer like myself. i understand aluminum is the lightest but its also very soft.
Material.........................................d ensity (lb/in^3)
Titanium, Ti.............................................0.1 63
AISI 1030 Steel, cold drawn.....................0.284
titanium is much lighter. .163/.284 = 57% lighter.
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 »</TD></TR><TR><TD CLASS="quote">hmm, maybe everyone should just forget about what i need the thread size for and respond if you know the size and pitch only. i don't need the socket size. </TD></TR></TABLE>
22 x 1.5mm according to section 18-8 of the Helms manual.
So Titanium nuts are going to remove 57% of how much? Four ounces? You going to be able to knock the divot into the axle keyway on a Titanium nut so it doesn't back off? Once that's done, are you going to be able to remove the divot when it comes time to change the axles? How much do they cost?
Just curious, but the measurement you need is right there
Go Tigers!
Re: (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 »</TD></TR><TR><TD CLASS="quote">by the way, you sir, are an idiot. don't ever question a mechanical engineer like myself.</TD></TR></TABLE>
pissing match FTW
just remove the mounting screws that hold your rotor in place.
pissing match FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Just curious, but the measurement you need is right there </TD></TR></TABLE>
i appreciate it. my comment about wanting to use Ti nuts was merely to stir up some ****. anyway my axles don't have a keyway for the divot, they are DSS stage 5's, they have a hole for a cotter pin.
check this site out for the prices.... http://www.tastynuts.com/site/...e.htm
Go Tigers!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 »</TD></TR><TR><TD CLASS="quote">by the way, you sir, are an idiot. don't ever question a mechanical engineer like myself. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 »</TD></TR><TR><TD CLASS="quote">i appreciate it. my comment about wanting to use Ti nuts was merely to stir up some ****.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">So what was the point of the thread?</TD></TR></TABLE>
i'm modelling one in Pro/E.
Go Tigers!
i'm modelling one in Pro/E.</TD></TR></TABLE>
nobody cares.
nobody cares.
