average cost to swap motor honda civic
Old 10-14-2007, 06:57 PM
souljah_jon's Avatar
Default average cost to swap motor honda civic
Does anyone know whats the average cost to swap motors
for a 2000 honda civic?
thanks.
souljah_jon is offline
Old 10-14-2007, 06:59 PM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Default Re: average cost to swap motor honda civic (souljah_jon)
$0-$965198498198495619849819849619877
More info, please.
B serious is offline
Old 10-14-2007, 07:20 PM
Default Re: average cost to swap motor honda civic (B serious)
im thinking just the head for honda civic si motor
the motor now isnt good. it might have a broken piston ring
id rather just change the motor than having someone fix
the broken ring
Old 10-14-2007, 11:19 PM
anyone know? please let me know..
Old 10-14-2007, 11:30 PM
hmtcrxsir's Avatar
You will need a OBD2B engine. Which exactly what a 99-00 Civic Si B16a2 is! Ill say it would run you about $2000-$2500 for swap depending on where you go. I would highly recommend you do a bit more research on this before you actually do this swap. But Hmotorsonline.com has some really competitive prices on the net. Or if you can find a shop thats closer to you that'll be better because of the shipping charges. But be ready to put out another $500 more of what is planned. You might run into some complications along the way.
hmtcrxsir is offline
Old 10-14-2007, 11:31 PM
hmtcrxsir's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by souljah_jon &raquo;</TD></TR><TR><TD CLASS="quote">im thinking just the head for honda civic si motor
the broken ring</TD></TR></TABLE>
oh btw, you can not swapped just the head from a B16 due to its interchangability of a D series motor and a B series motor.
Old 10-14-2007, 11:33 PM
BigChina's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by souljah_jon &raquo;</TD></TR><TR><TD CLASS="quote">im thinking just the head for honda civic si motor</TD></TR></TABLE>
wait wat model civic do u have cuz im confused wat u have. and y do u want just the head from a b16?
BigChina is offline
Default Re: average cost to swap motor honda civic, labor cost (hmtcrxsir)
i just want to know the labor cost to have
a shop do it.
Old 10-14-2007, 11:34 PM
Default Re: average cost to swap motor honda civic, labor cost (souljah_jon)
civic 99 si motor
Old 10-14-2007, 11:36 PM
Default Re: average cost to swap motor honda civic (hmtcrxsir)
yah i just want the labor cost.
how much would a shop charge?
Old 10-14-2007, 11:43 PM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by souljah_jon &raquo;</TD></TR><TR><TD CLASS="quote">yah i just want the labor cost.
how much would a shop charge?</TD></TR></TABLE>
how much would a shop charge to put in a motor? What motor is allready in there?
Anywhere from $500-1000. If you pay $1000, you're getting ripped off hard. Try to get it for somewhere around $500 for labor costs. It's not a big deal to do a swap on these cars. I've done millions. It's to the point that from the time we pull the car in the garage, it's an hour and a half till the old motor and the car are sitting on the ground. Strictly hand tools and jacks and jackstands.
Old 10-15-2007, 12:44 AM
hmtcrxsir's Avatar
do it yourself and learn something if you have any questions we are here for you.
Old 10-15-2007, 03:30 AM
ron212002's Avatar
Just do alot of research first . I am doing my own for the 1st time , but going to read up for a very long time before I try .
ron212002 is offline
Old 10-15-2007, 07:59 AM
B serious's Avatar
Default Re: average cost to swap motor honda civic (ron212002)
its easy. you can throw it in, and it will pretty much bolt itself up.
Old 10-15-2007, 08:49 AM
hondamark35's Avatar
the shop i work at charges around $2200-$3000 out the door depending on the car. this is for replacing a blown factory engine with the same or similar engine. this price inlcudes the motor (between $400 and $900) all of the major engine seals, crank seal, cam seal VC gasket, rear main... and so on. we also do a timing belt package for good measure and all new coolant hoses.
in the case of a swap, there would be extra for mounts, axles, ecu, various rewireing, and other odds and ends.
so i would think around $700 labor would be fair if the shop did swaps often and were familiar with the specific setup and had the right tools and knowledge.
but do it yourself. there are few things that bother me more than someone who wants a faster car but doesn't want to do the grunt work themselves. it's fun anyway..
hondamark35 is offline
Old 10-21-2007, 12:07 PM
Default Re: average cost to swap motor honda civic (hondamark35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamark35 &raquo;</TD></TR><TR><TD CLASS="quote">the shop i work at charges around $2200-$3000 out the door depending on the car. this is for replacing a blown factory engine with the same or similar engine. this price inlcudes the motor (between $400 and $900) all of the major engine seals, crank seal, cam seal VC gasket, rear main... and so on. we also do a timing belt package for good measure and all new coolant hoses.
but do it yourself. there are few things that bother me more than someone who wants a faster car but doesn't want to do the grunt work themselves. it's fun anyway.. </TD></TR></TABLE>
thanks for the info.. tools and time is needed to do this..
Old 10-21-2007, 01:27 PM
playskool's Avatar
lets not lead this guy down the wrong path. a honda swap is on the easier end of the spectrum, if you have worked on cars or have friends familiar with mechanics. but you cant just throw it in there and expect it to run. you will need good tools (hand tools will work), but a decent impact will make your life easier even a cordless one will help a bunch, a cherry picker, a couple of friends, and the knowledge you picked up doing your research, another VERY IMPORTANT peice of equipment will be the service manual.. get the HELMS. take your time and dont expect it to be a day long job. It gets done all the time but theres always something you miss. plan and plan some more. if all else fails pay the 500 and get a shop to do it.
playskool is offline
Old 10-21-2007, 03:38 PM
DaYZeD.1's Avatar
you are looking at 3 g's and do the labor yourself.... or about 2500 for a B16
DaYZeD.1 is offline
Old 10-21-2007, 05:08 PM
1sickEJ's Avatar
most bang for your buck u said the pistons fuckd up right .. go buy a ls block for like $100-$200 throw the b16 head on there and go.. well theres some things youll have to do in between there but take if your gonna let a shop expletive your car up then let them deal with it i wounldnt pay a penny over $1000 out the door b18b bottom ends are in surplus labour and parts a round $800 ...
1sickEJ is offline
Old 10-21-2007, 07:48 PM
robfrmny21's Avatar
why you asking us about labor like we are a auto shop. start calling some shops or go into on and ask
robfrmny21 is offline
Old 10-21-2007, 08:16 PM
H-T White Ops
NOFX's Avatar
Wait... You have a 2000 Civic Si, right?
And so are you asking to just swap the head? Or do you want to swap the entire motor?
NOFX is offline
Old 10-21-2007, 11:11 PM
Default Re: average cost to swap motor honda civic (NOFX)
just need to change the head... looking around
Old 10-22-2007, 04:39 AM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by souljah_jon &raquo;</TD></TR><TR><TD CLASS="quote">just need to change the head... looking around</TD></TR></TABLE>
I thought you said the piston ring(s) were bad.
ddd4114 is offline
Old 10-22-2007, 06:46 PM
hmtcrxsir's Avatar
Default Re: average cost to swap motor honda civic (ddd4114)
I thought he said he has a 2000 Honda Civic Si w/ bad pistons? Now what good does it do if you have bad rings and you want to replace the head. Two seperate things.
Old 10-22-2007, 06:49 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">I thought he said he has a 2000 Honda Civic Si w/ bad pistons? Now what good does it do if you have bad rings and you want to replace the head. Two seperate things. </TD></TR></TABLE>
Nice ninja edit
ddd4114 is offline
Lightsped
K Series
03-26-2012 10:01 PM
elhartd
18
11-22-2010 05:35 PM
95vtechonda
07-11-2006 01:38 PM
Quick Reply: average cost to swap motor honda civic
