Average cost to replace CV Joint? - Honda-Tech
Old 04-23-2006, 08:37 AM   #1
CRISIS's Avatar
Default Average cost to replace CV Joint?
Is it really expensive? I was just curious because all the shops in my neighborhood are closed. It's for an eg sedan. Thanks.
CRISIS is offline   Reply With Quote
Old 04-23-2006, 08:42 AM   #2
Soccerking3000's Avatar
Default Re: Average cost to replace CV Joint? (CRISIS)
uhh you would just replace the axle they are like 40 bucks fron honda
Soccerking3000 is offline   Reply With Quote
Old 04-23-2006, 08:59 AM   #3
CRISIS's Avatar
Default Re: Average cost to replace CV Joint? (Soccerking3000)
Isn't a cv joint a piece on it's own? Also would it make a clicking noise when i go in a straight line? Or would that be the axle? I'm so confused.
Old 04-23-2006, 09:06 AM   #4
the cv joint is part of the axle, it allows the axle to bend with the suspension, and yea it will make that clicking noise, just replace the axle, they are one in the same essentially. If you replace the axle the cv joint is replaced as well because it is part of the axle...
Old 04-23-2006, 09:17 AM   #5
CRISIS's Avatar
Then what is the piece that is behind the axle? More towards the back of the car. It has a tie rod at the end of it. The boot is busted and it started making noise. Covered it with lube and it went away. But now the sound is back. :-( Sorry i don't have any pics.
Old 04-23-2006, 09:21 AM   #6
JeBuSrIcE's Avatar
thats the steering rack...u can change the boots out and put lube back in.....its not that expensive
JeBuSrIcE is offline   Reply With Quote
Old 04-23-2006, 09:24 AM   #7
CRISIS's Avatar
Default Re: Average cost to replace CV Joint? (JeBuSrIcE)
But that wouldn't cause the clicking would it. And what will happen if my axles snap?
Old 04-23-2006, 09:24 AM   #8
Quote:
i've seen this done, but i would still just replace the axle, you have to pretty much take the old one out either way so why put one back in that might still be damaged
Old 04-23-2006, 09:52 AM   #9
Hondaciv95VX's Avatar
REPLACE THE AXLE! EASIER, and you will get a warranty on the axle, which includes the boot.
Warranty = owned.
Hondaciv95VX is offline   Reply With Quote
------------------------ thaijdmpart For Sale 0 11-20-2014 12:37 AM
Completed Robin6 Road Racing / Autocross & Time Attack 76 06-17-2013 06:42 PM
. allJDMcivic Honda Civic / Del Sol (1992 - 2000) 9 12-16-2010 05:03 PM
. gotstableo Honda S2000 0 06-03-2007 04:14 PM
a sleepyEK Honda Civic / Del Sol (1992 - 2000) 11 12-12-2003 01:54 PM
Tags
03, 2003, 92, average, axle, civic, cost, costto, crv, cv, honda, joint, joints, pilot, price, put, replace, typical
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
