Is the Autozone b16 head gasket any good???
im doing a built b16a2 bottom end with a gsr head, i used a gsr head gasket and for some odd reason its leaking.. should i use a b16 head gasket? and is autozone b16 head gaskets any good? i cant afford going to honda and buying a $100 head gasket when i can get a FREE b16 head gasket from autozone.
has anyone ever used a autozone head gasket? let me know how was it and if it was anygood. thanks!
Re: autozone head gasket??
i used one one my d15, its a composite. but since i was swapping the motor i didnt care. it held up fine until i pulled it, and its still running strong in a friends car.
yeah thats the thing though.. imma be boosting. i was boosting 20lbs and my timing jumped 4 teeth and bent 5 vavles.. you think that autozone head gasket is good for boost? its gonna be a daily 12 pounds
The autozone headgasket is made by fel-pro which makes good gaskets. What the issue is with people have headgasket issues is: cooling system issues, bad tunes (lean makes more heat and destroys headgaskets), or not using arp head studs to keep the head from lifting. All B-series headgaskets are steel only the d15's had composite gaskets. Make sure you have your head resurface and block checked for levelness.
Re: Is the Autozone b16 head gasket any good???
Fel Pro isn't just autozone. Fel Pro is a gasket company. They sell through O'Reilly/CSK, too.
Fel Pro makes good gaskets, but Honda makes much better OEM parts. If you're boosting, go OEM. I wouldn't trust eBay head gaskets to my enemy. It's a head gasket, not a thermostat seal. You know what I mean?
