Automatic transmission car wont move question
Sexy Cheese Cake
Put a transmission into a 94 Civic DX and now i have this problem. Car will drove fine for about 5-10 minutes then all of the sudden the transmission slips and then just goes away completely. What has be scratching my head is i can turn on the car (completely remove key) and start it right back up and it runs fine for the short period. If i do not turn it off the car will sit in gear and not move at all. I unplug the lock up solenoids and the car acts the same.
Anyone have anything i can check?
Thanks Dave.
Thanks Dave.
Re: Automatic transmission car wont move question
i had this problem with a chevy 3100 trans that slips after a little driving
turns out the trans was overfilled, and when check while it was slipping, the trans fluid was bubbly
Sexy Cheese Cake
I check the fluid while the car wouldnt move and it was good. I can leave the car in gear and get out. The car wont move at all. I turn the key to completely off, then turn on and the car will move. It drives fine otherwise, up until it decides to just completely give out.
Seems i cant catch a break with these transmissions lol. Got this one from some a salvage yard and now this. Guessing i will have to pull this one and maybe 3rd time will be a charm.
sounds like you need to start looking for a new transmission. this is what happens when a honda transmission is burnt up. i dought a cooler will fix anything.
