ARP Head Studs vs OEM Head Bolts - Honda-Tech
Old 05-23-2004, 03:22 PM   #1
simplypinoyy's Avatar
Default ARP Head Studs vs OEM Head Bolts
I am planning to get new bolts for my Mini Me set up of a d16y8 Head onto a d15b7 block.....oil is leaking through in between the head and block... so im burning the oil and leaking it ... double the trouble... Im thinking that the problem are the bolts because i used the old d15b7 bolts and since the d16y8 head has different bolt spex esp the one on the topleft corner (when your looking at the head from the top) before i order them which is better to get... go to honda dealers and order OEM head bolts for the y8 head or buy the head studs and go through the extra trouble of putting them in?
simplypinoyy is offline   Reply With Quote
Old 05-23-2004, 03:43 PM   #2
SiShane's Avatar
Default Re: ARP Head Studs vs OEM Head Bolts (simplypinoyy)
if you got the money and are planning to go boost or high comp, Id do it to get it out of the way. But if this is a mild street setup with bolt ons I wouldnt worry about it and get the honda bolts.
SiShane is offline   Reply With Quote
94 civic dx d15b7 oem head bolts/arp studs willisjefferyl Honda Civic / Del Sol (1992 - 2000) 9 04-09-2013 08:11 AM
what head bolts to use d15b7inEF Honda CRX / EF Civic (1988 - 1991) 2 03-19-2012 08:43 PM
d15b7 distributor on a d16y8 head? Bense Honda Civic / Del Sol (1992 - 2000) 5 01-08-2006 01:02 PM
WTB: d-series head swap stuff: Head studs, gaskets, timing belt, etc... civicmatt Want to Buy 1 05-10-2003 07:47 AM
how many lb's to i tighten my head bolts to? bluedelsol Tech / Misc 5 02-15-2003 03:35 PM
Tags
arp, bolts, civic, d15b7, d16y8, h22, head, headstuds, honda, install, main, oem, s2000, stock, studs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
