Apexi Turbo Timer Wiring in EG?
Old 03-08-2007, 04:36 AM
Weak!EG's Avatar
Default Apexi Turbo Timer Wiring in EG?
I have everything done.. then i got to the o2 wire.. anyone know which wire on the ECU plugs i use for this wire..
also, it says ground to the ecu engine ground and not the chassis when using the 02... where is the engine ecu ground located..
thanks in advance..
Old 03-08-2007, 05:47 AM
Projekt_2nr's Avatar
Default Re: Apexi Turbo Timer Wiring in EG? (boostedsingle)
http://www.roadraceengineering...g.pdf
Old 03-08-2007, 09:01 PM
work?
BOOSTED92EG
02-01-2006 11:38 AM
RICE POLICE SIP
12-23-2002 01:51 AM
TurBoXBirD16
10-10-2002 09:16 PM
kuelerz
10-04-2002 10:38 AM
Quick Reply: Apexi Turbo Timer Wiring in EG?
