Anyone know how to install A/C Receiver Dryer?! - Honda-Tech
Old 05-02-2011, 09:45 PM   #1
Default Anyone know how to install A/C Receiver Dryer?!
So, I was told that if I replace my a/c compressor that I also need to replace my receiver dryer and do an evacuation along with a recharge. Is that right? If so...is there any precautions or anything I need to know before replacing my receiver dryer, like do I need to do an evacuation before I install it or after, or any special way to replace it? I am just curious as I am going to try to replace it tomorrow. Let me know if you have any advice. Thanks!
hcs1jimmy is offline   Reply With Quote
Old 05-02-2011, 09:51 PM   #2
Default Re: Anyone know how to install A/C Receiver Dryer?!
What car?
When a compressor fails, it can generate metal debris that can cause the A/C system to fail again. Therefore, it would be prudent to flush the system, replace the receiver/dryer, evacuate for at least a few hours, leak test overnight, and then recharge with oil and refrigerant.
Former User is offline   Reply With Quote
Old 05-02-2011, 09:51 PM   #3
Linked's Avatar
you need to recover all the refridgerent from the system before removing your old reciever drier
if there isnt any in the system because the system was open to the atmosphere, then you can just unbolt the receiver drier
Linked is offline   Reply With Quote
Old 05-02-2011, 09:54 PM   #4
It's for a 95 civic. The system was open for awhile, but I'm not sure if there was still refridgerent in the system still or not.
Old 05-02-2011, 09:57 PM   #5
Linked's Avatar
like ron said before, was there any problems with the system before?
why was the system open?
and no there wouldnt be anymore refrigerant in the system anymore
Old 05-02-2011, 10:01 PM   #6
Well, the compressor clutch went out on the old compressor so I wrapped the lines until I could get a compressor again.
Old 05-02-2011, 10:10 PM   #7
Linked's Avatar
if you only replaced the compressor and wrapped the lines
then yes, you wouldnt have any refrigerant in the system, and can install the receiver drier
after you would evacuate the system and pull it into a deep vacuum. alot of AC service carts would hold vacuum for ~20 minutes.
after it confirms the system can hold a vacuum then there shouldnt be any leaks and they'll charge it.
you need to make sure to alert whoever is charging your system that you replaced your compressor, so they can recharge the right amount of oil into the system.
Old 05-02-2011, 10:14 PM   #8
does it matter if it is a used compressor? I mean, as far as how much oil they put in? Also, do you know about how much (on average) a shop will charge to do all that?
Old 05-02-2011, 10:20 PM   #9
If only the compressor clutch was bad, why replace the entire compressor? And it's possible to replace the clutch without disconnecting the A/C lines, though it's too late for that now.
Old 05-02-2011, 10:22 PM   #10
Linked's Avatar
i dont know how much a shop would charge to charge your system, best bet is to call your local shop and ask (i wouldnt recommend a low quality shop with ac work though, they tend to only have one ac cart and will reuse unrecycled refrigerant)
and since the compressor is used, you run the risk of having contaminants in the compressor and also metal shavings that can clog the system
the best route to take at that time would be to assemble everything, install an inline filter on the highside right after the compressor then flush the system
Old 05-02-2011, 10:23 PM   #11
oh i just didn't want to mess with replacing it plus my buddy just gave me his perfectly good compressor.
Old 05-02-2011, 10:27 PM   #12
Linked's Avatar
describe the compressor, you got it straight out of his car while it was working? or he had it laying around?
Old 05-02-2011, 10:35 PM   #13
ya straight out of his car.
2004 Honda Accord bad Receiver/Dryer ZachFey Honda Accord & Crosstour (2003 - Current) 1 06-08-2015 10:01 PM
DIY AC about ac \ systems r134a .... ALSO Freon just ADD You get a wal-mart donst work!! gulftiresinc Paint and Body 3 04-26-2007 02:55 PM
Is it really necessary to change the dryer when working on the AC system? supadupamikey General Discussion and Debate 9 06-19-2006 08:18 PM
A/C replacement 89JDMcrx Honda CRX / EF Civic (1988 - 1991) 17 08-15-2005 09:26 PM
do i need to evacuate my ac system? c1civic Honda Civic / Del Sol (1992 - 2000) 14 05-15-2005 03:55 PM
Tags
1994, 2000, ac, charge, civic, dreyer, drier, drierreciever, dryer, honda, installing, integra, reciever, reciver, replace, replacing, system, taking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
