Any ideas on how to remove belt-driven crank pulley, please?
Old 09-11-2015, 05:45 AM
civiclady's Avatar
Default Any ideas on how to remove belt-driven crank pulley, please?
I have been doing my timing belt replacement along with a few other things on my D15B7 (1994). Every bolt in this car seems to be a pain to remove! (It has 280,00 miles). I finally got the crank pulley bolt off after breaking a couple of breaker bars and sockets. The timing belt was cracked but clean yet the timing belt back cover was full of oil. I want to change the oil seal on the crankshaft behind the belt-driven pulley but I cannot wiggle it loose. It got the big pulley the AC, PS, and alt belts go on. That slid off. But the toothed pulley is on there hard. I am considering cutting it or taking it off with some pulley pullers but I rather not damage it if I can help it. I have sprayed lots of PB Blaster on it and banged it with a rubber mallet. Would covering it with a large socket and banging on it hard to shake it loose a bad idea? Any other ideas I can try?
Old 09-11-2015, 05:52 AM
Stancetard Hate Monger
eghatch9295's Avatar
Default Re: Any ideas on how to remove belt-driven crank pulley, please?
https://honda-tech.com/honda-civic-d...moval-2892443/
Old 09-11-2015, 06:12 AM
Fish Twig
tony_2018's Avatar
I was thinking the bearing puller, or 3 tooth puller. Whatever its called.
Old 09-11-2015, 09:05 AM
civiclady's Avatar
Thanks a lot, guys. I finally got it. I wrapped it in a thick piece of rubber sheet and put a hose clamp around the rubber with two long bolts on either side just under the hose clamp. I was able to wiggle it off by pulling the two bolts with a couple of pliers. If this had not worked I would have tried using a puller with the legs on the hose clamp, but I am glad this got it!
Old 09-12-2015, 08:09 AM
PHANTOM MENACE
24TEN's Avatar
^Pretty ingenious idea!
Old 09-13-2015, 06:33 AM
Jimi Hondrix's Avatar
I used the claw end of a hammer and gently pried it between the block and back of sprocket, working in circles..nudging forward bit by bit to ensure would come off evenly. Worked well in my case.
ABCVTEC
09-10-2010 01:01 PM
EG6 Love
03-18-2008 05:33 PM
dfabulous
10
12-09-2007 11:00 PM
Bullet113
12-07-2006 02:16 PM
h46it
03-21-2002 07:57 AM
Quick Reply: Any ideas on how to remove belt-driven crank pulley, please?
