Another 3rd gear grind
Old 11-30-2005, 02:07 PM
JimmyAtlantis's Avatar
Default Another 3rd gear grind
I know 3rd gear grinds have been brought up several times in the past, but I want my own thread. I just test drove a 94 ex (d16z6). 3rd gear grinds ONLY if you shift quick (but I'm not talking about mashing). It goes in fine with a nice smooth normal shift. The shifter also feels a little sloppy going in to 3rd. I'm sure everybody's going to tell me it's the syncro. WILL GM SYNCROMESH FM FIX MY PROBLEM? j/k How much is it going to cost me to replace the syncros?
Old 11-30-2005, 04:00 PM
Default Re: Another 3rd gear grind (JimmyAtlantis)
Old 12-01-2005, 01:53 AM
Too technical? Help me out here.
Old 12-01-2005, 02:37 AM
Hybrid96EK's Avatar
This is not a repair shop. Want a repair quote? Call a shop. If you lived by me and wanted me to do it, $200 is what I would charge + you supply me with the synchros.
Old 12-01-2005, 02:52 AM
Default Re: Another 3rd gear grind (Hybrid93Eg)
Where do I find syncros? Do I have to get entire transmissions or can I call around and have something pieced together?
Old 12-01-2005, 04:44 AM
And is that what it sounds like the problem is...the syncros?
Old 12-01-2005, 06:12 AM
snatch's Avatar
It does sound like synchros. GM synchromesh will only mask the problem. You can buy a new synchro set from Honda, but I would imagine buying that and putting it in would cost as much if not more than a new (used) tranny. Of course then you run the risk of the next tranny having some issues.
Old 12-01-2005, 06:16 AM
sheBangZ's Avatar
d16 trannys are a dime a dozen. do a search on here and you can score one for 200 maybe 300 bucks if your lucky. you get the syncros for honda for pretty cheap, its the labor cost if your not a do it yourselfer that will hurt you, but chances are if you don't know what syncros are then the labor for putting in the new tranny would be the same. bring it to a shop and let them do it.
Old 12-01-2005, 07:25 AM
brusk13's Avatar
you can't just go to honda and buy a synchro, they only sell the whole gearset and it's between 200-300 bucks and that just helps that gear. http://www.gear-speed.com has carbon synchros $225 for the set for D series trans. That's the option I'm going to go with. You feel like driving down to MD we can have it done in a day. Labor cost is probably about $400 I'm guessing here depending on how many labor hours the book says but probably about 10. Should only take about 3 hours to do it realistically. We just did my roommates del sol and we can have it out and on the table in 25 minutes now.
Old 12-01-2005, 07:31 AM
Default Re: (brusk13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brusk13 &raquo;</TD></TR><TR><TD CLASS="quote">you can't just go to honda and buy a synchro, they only sell the whole gearset and it's between 200-300 bucks and that just helps that gear. http://www.gear-speed.com has carbon synchros $225 for the set for D series trans. That's the option I'm going to go with. You feel like driving down to MD we can have it done in a day. Labor cost is probably about $400 I'm guessing here depending on how many labor hours the book says but probably about 10. Should only take about 3 hours to do it realistically. We just did my roommates del sol and we can have it out and on the table in 25 minutes now.</TD></TR></TABLE>
How about I drive down, help with the project and get charged clock time instead of that stupid *** book bs. That I might be down for.
Old 12-01-2005, 09:01 AM
hondakevin21's Avatar
GM Synchromesh will work depending on how bad the synchro is, try it out.
Old 12-01-2005, 09:03 AM
GM Synchromesh might work depending on how bad the synchro is, try it out. That other guy is right it usually only masks the problem eventually it will go out but this only extends that time a little bit.
Old 12-01-2005, 09:43 AM
Default Re: Another 3rd gear grind (hondakevin21)
I was really just kidding (j/k) about the syncromesh. I know it won't fix it. I'm going to use it anyway until I get my hands on another tranny or whatever I'm going to do.
Old 12-01-2005, 11:01 AM
hushypushy's Avatar
my 3rd gear grinds if i shift really fast and incorrectly, perhaps that's what you're doing?
if you shift too fast for the tranny, it grinds.
and uh...sorry if you feel im treating you like a noob, but hey that could be it, i thought my tranny was fucked when i'd shift to 3rd and it was grinding then i changed the way i shifted and now it works perfectly
Old 12-01-2005, 11:04 AM
Hybrid96EK's Avatar
Default Re: (hushypushy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hushypushy &raquo;</TD></TR><TR><TD CLASS="quote">my 3rd gear grinds if i shift really fast and incorrectly, perhaps that's what you're doing?
and uh...sorry if you feel im treating you like a noob, but hey that could be it, i thought my tranny was fucked when i'd shift to 3rd and it was grinding then i changed the way i shifted and now it works perfectly</TD></TR></TABLE>
There is a difference between shifting fast and shifting like an *** clown. If the teeth on the synchro are in good shape as they should be then shifting fast should NOT cause any problems.
Old 12-01-2005, 11:10 AM
I've been driving stick for 9 years. I've been driving my Civic for 2 including track events and many autox's. I know how to shift fast and I can even do it without mashing the gears. There should be no grinding when shifting regardless of shift speed. How did you change your shifting? Slow it down? On a track or autox course slow shifting is NOT an option. But I thank you for your input and suggest you replace yours as well.
Old 12-01-2005, 04:13 PM
brusk13's Avatar
our labor rate is $50/hr which is almost half the price of any dealership it wouldn't realy be worth it to only charge actual labor time but depending on what the book says we might be able to work out a deal. As for helping, not to be rude in anyway but you'd probably just get in our way. Unfortunately more than two people working in an engine bay doesn't work out to good.
peel17
12-06-2005 03:01 PM
Bond
01-31-2005 07:14 PM
TypeRTexan
04-13-2004 11:30 AM
b20civic
09-08-2002 11:33 PM
onyx00
07-26-2002 06:57 PM
Quick Reply: Another 3rd gear grind
